dual port bov
Old Feb 13, 2009 | 08:30 PM
hallss's Avatar
dual port bov
http://www.turbosmartonline.com/index.php?id=46
hey i was wondering if anyone has seen these yet??? i may be wrong but couldn't you use the dejon ic piping with the correct flange and run full recirculation, then once you get a tune vent to atmospere??
i was also wondering where i can get a blockoff plat for the stock bypass valve?
Old Feb 14, 2009 | 04:55 PM
redcomet303's Avatar
dont see why not but I would just go recirculated and leave it. VTA is for noise effect only.
Old Feb 14, 2009 | 05:49 PM
MaxVQ35DE's Avatar
if performance is your goal then stock or recirc is the only way to go. VTA on a stock turbo is just for riceboys. If you are going recirc just make sure spring pressure is not too different than stock, twin scrolls arent cheap
Old Feb 14, 2009 | 06:45 PM
hiltu's Avatar
block off plate from bald turbo freak for $30 or from hahn for $45
Old Feb 14, 2009 | 06:47 PM
BartSS's Avatar
I need to get myself a block off plate for sure.
Old Feb 14, 2009 | 07:03 PM
COUGH COUGH
I didn't have a block off plate when I had my aftermarket BOV on and It never opened.
just hook it up to a boost only source and put a check valve inline and that baby will never open.
Old Feb 14, 2009 | 07:58 PM
BartSS's Avatar
That's how I have it now and its no problem I've just been hearing that running a block off plate would be better
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 13, 2015 09:32 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
