Dyno tuned with synapse stage 3 kit
well i would fix it if a had the money and i have had the kit for a few months now. but when i do get the money i will be getting better stuff in the engine. but there is a high chance that i had blow by before i put the kit on. plus i spend to much money on my other car.
Moron!!
i never knew they made 2 bar MAF sensors.... since a MAF sensor measures air flow by volume..... a bar is a pressure measurement..... 1 bar is equal to 14.7 PSI..... now u know
You obviously dont read the whole post he has plus the mods he has........ He needs IC, Charge pipes, CAI and two or so more lbs of boost ... That should be worth 28-34 more whp...
Some guys are getting 330-335whp on stock turbo with no upgrade turbine wheel or anything else.....
Plus, the DI engine likes the heat, it creates a better, more complete fuel burn in DI cars....
Lastly do yourself a favor as many of the kids on this site do not understand... anytime you add more than 70 or more whp to ANY car, you need to increase the size of your fuel pump otherwise you'll have starvation. R\R the fuel pump before you upgrade the DI system.... >> ( which we are all waiting on HPT to free up the Fuel system under the hood)........._
Yes, he might be able to make similar pwr with the stock turbo at 28+ psi and at this rate the turbo will not last at all....
well might be selling the turbo and maniflod to a buddy of mine. and just get the k04+ upgrade so i can keep it safe and not have to can things out for any work that needs to be done. but my buddy it building a turbo cavalier because there is not a lot of them plus it going to be a fully built car ground up. but depends on what the dealer is going to say.
