E85 fuel???
E85 fuel???
Just wondering if it's possible to run e85 on the ss/tc! Are the injectors capable of running it and also the motor? I would imagine fuel lines would have to be changed and car would prolly have to be retuned to account for the fuel difference! Just looking for some info about it and maybe some suggestions to go about putting it together? Correct me if I'm wrong but I would think the actuall performance of the car would increase such as hp and tq curve with what I have heard it does only get 2 to3 mpg less then running 93 oct! Let me know what you guys think about the idea please correct me if in wrong, just be gentle!!
i figured there would be easier ways to get more power than this, considering you will have much higher fuel needs and that seems to be one of the physical limits of the LNF
Thanks Matt. I was looking at it from the cyl cooling angle as well as KR that is constantly an issue for me.
If it's about the same HP and it'll have enough fuel for 7k rpm's I'd be willing to try it. I've read about the pulse widths not being wide enough to support the amount of fuel needed though.
I would convert my LNF to take hydrogen = more power and fuel effiencent. If it was possible. Hydrogen is really the true alternative fuel of all, done a paper on it in college. Better than running on electric battery and E85.
A quick conversion using the Stoich of 14.7 for gasoline and 9.765 for E85 means my Lambda at cruse would be .666 to compared to 1.0 on gas and .586 would be the ~.88 I run WOT now if I did it right. Lots more fuel needed. Be nice to know if it'd work or eat anything up.
for the RPM range where you arent runing close to the physical limit of the pump your car would a decent power boost until you reached static flow from injectors and then your car would die.
A fully bolted LNF runs very close to its fuel limits. E-85 requires about 30% more fuel.
Plus is smells like popcorn.
Plus for those who give a crap, good for enviornment.. blah blah blah.
did quite a few projects on this subject. Definitely not that good for the enviroment, really ends up being a wash when you look at all the effects
so it basically does the same thing as meth injection without the meth injection. well i guess it is 85% meth so that would be why. Another reason to run meth even without a tune, it ups ur octane so no worries about getting cheap ass gas as some stations have.
All the hoses and components that handle fuel on our car are rated for atleast E20. The process for making hoses E20 proof is much the same as making the E85 proof.
