Eng pwr reduced
Old 04-27-2018, 11:24 PM
ShizahSS's Avatar
Eng pwr reduced
2010 ss lnf. recently retuned by zzp for intercooler and 3 bar map sensors.
ever since I got ecu back I get ENG PWR REDUCED every 5 - 20 mins while driving and usually while off throttle. NO CEL and no reduced power is noticed, car hauls.
upper map sensor plugs 99% of the way into harness but wont click into place, no bent pins and all looks good, im thinking it might be the issue but not sure.
zzp isnt being very helpful which is disappointing so any input is appreciated.
Old 04-28-2018, 12:38 AM
Sharkey's Avatar
so there is no check engine light, but is there any codes? not all codes will turn on the check engine light
Old 04-28-2018, 01:22 AM
ShizahSS's Avatar
No codes are shown by torque pro
Old 05-01-2018, 06:51 AM
ShizahSS's Avatar
anyone have any ideas?
I cleaned my maf and map sensors with sensor cleaner and that seemed to help a little, now I get the eng pwr reduced not so often but its still there.
Old 05-04-2018, 09:54 AM
umrdyldo's Avatar
Can you use torque pro to watch the MAP sensor? The 3 bar sensors can be very finicky if not plugged in all the way. Car should throw a code for sure.
Old 05-04-2018, 10:05 AM
Slobodan Milošević
07blackg5's Avatar
Have you contacted zzp?
Old 05-04-2018, 02:11 PM
cluelessk's Avatar
x2. You made a change. Problems started. They're probably related
Old 05-04-2018, 03:17 PM
ShizahSS's Avatar
ZZP isnt much help at all
I told them whats happening and their response was "the car drives fine so tune is fine" lol
I try and see if torque can see the map sensors
Old 05-04-2018, 08:16 PM
cluelessk's Avatar
Checked for leaks after intercooler install?
ShizahSS (05-04-2018)
Old 05-04-2018, 09:15 PM
ShizahSS's Avatar
No I didnt think to lol have plans for the weekend now
that would cause this issue? I cant really find anyone who has ever had this happen
Old 05-04-2018, 11:03 PM
cluelessk's Avatar
Start with the simple stuff.
First place to look is the stuff you touched last. It was working fine before. Double check everything that was touched when you worked on it. Tune could still be an issue.
And for the plug not clicking into place fully. Try using something to lube up the seal in the plugs.
Old 06-10-2018, 06:23 PM
ShizahSS's Avatar
so ive been away working but ive finally had some time to play with the car.
no boost leak or anything I can find wrong at all.
car still tosses error at 2800-4000 rpm when off throttle and hesitates when you get back on it for a second after, then all is fine, no codes nothing.
anyone have any ideas? im really thinking its the tune as this never ever happened before my last revision but ZZP says they only changed the emissions.
dont know what to do and want my car back to the way it was
Old 06-12-2018, 06:39 PM
Evilfrog's Avatar
First step would be to switch back to the old tune. It sounds like you did an ECU swap, so I don't know how hard that would be. Was it a stock tune before? If it was, find someone with HP tuners, export the current tune, and have a dealership reflash it. (or if ZZP could pull it off of the core you sent them.)
If it goes away, you know it was the tune. If it doesn't, continue troubleshooting.
Just to clarify, did you run it after the parts were installed, without the tune and it ran fine?
Old 06-12-2018, 06:52 PM
ShizahSS's Avatar
ecu was sent to zzp for flash and I have no access to hptuners.
car had a zzp tune before this all happened, I got reflashed for intake,3bar sensors and IC.
timeline of events..... stock car>zzp tune for catless dp>retune for intake,sensors and IC> retune again for emissions.
never had this issue at all until last flash.
zzp asking me to send in to reflash back to tune before emissions to see if it helps.
im confused cause I seem to be the only person in the world to ever get this error without a CEL or code and no effect in performance besides a little hesitation now and then
Old 06-12-2018, 07:02 PM
cluelessk's Avatar
Could a sensor be DOA?
I know it's really common to have install issues with sensors.
Old 06-12-2018, 07:21 PM
ShizahSS's Avatar
funny you say that cause one of the sensors wont plug in all the way to harness.
it plugs 99% of the way but wont "click" if that makes sense
I mentioned this to zzp and they didnt seem to think its an issue
double clutch
08-21-2017 03:31 PM
ripped
08-06-2010 12:40 PM
gomy_ss
06-26-2009 01:39 PM
Striped_SS
03-20-2009 09:25 PM
Hopeless Regret
08-15-2007 09:16 AM
Quick Reply: Eng pwr reduced
