Engine Ground Strap - Where is it located?
Old May 5, 2010 | 10:37 AM
pt5457balt's Avatar
I thought i had an alternator problem, but i think the person that worked on my car didn't know what he was doing and either routed it wrong, or just didn't connect it at all. Where is the grounding strap located on our cars (08+cobalt ss), and where does it run to?
Thanks!
Old May 6, 2010 | 07:02 AM
BLK08SS/TC's Avatar
I remember seeing a ground underneath the driver side headlight. You have to remove the headlight and bracked and you will see it there. Not sure if there are any more though.
Old May 6, 2010 | 09:33 AM
pt5457balt's Avatar
I think i've seen that one, and it looked connected.
I could just be screwed and need a new alternator. Only 27k miles too. damnit.
Old May 26, 2010 | 06:58 PM
pt5457balt's Avatar
Update:
Still having charging problems (glad i have two cars). Is this the proper routing for the grounding strap running under the driver-side headlight?
Also, what should be the routing for wires running off the Alternator?
Old May 27, 2010 | 09:29 AM
pt5457balt's Avatar
Bump. Someone has to know.
Old May 27, 2010 | 11:06 AM
SSlobalt's Avatar
Photos courtesy of Gestapo:
Old May 27, 2010 | 12:09 PM
pt5457balt's Avatar
Wow, complete wrong place on my part. Lol
thanks for the info! I know what I'm doing when I get home.
Old May 27, 2010 | 12:40 PM
SSlobalt's Avatar
It really shouldn't matter if the connection is good. Metal is metal.
Old May 27, 2010 | 02:28 PM
pt5457balt's Avatar
Just checked it all over again. Power wire retaining nut on the bottom of the alternator is loose as hell. Wire isn't making good contact. Can't believe i missed that.
Thanks for the help/input/pictures guys! It really got me under the car and looking!
Old May 27, 2010 | 06:54 PM
SSlobalt's Avatar
Good to hear you found something.
Old May 27, 2010 | 09:01 PM
pt5457balt's Avatar
yep, that was the problem.
Alternator was running wide open while it charged the battery at 14.6-8v. lol
biniecki
Oct 25, 2015 02:23 PM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
patooyee
Oct 1, 2015 01:07 PM
