engine issues!!!!!!!!! :/
so started it up the other day after not driving my lnf for a day go to pull it outa the garage and it stalls. start it back up and starts idleing funny. i dont think anything of it, yesterday i get on the highway and i noticed when i let off i have a cloud of blue smoke after i let off... went to my buddys and took him for a ride and he saw the same thing every time i let off. car still has power but seems weeker then normal. some friends told me maybe pcv, but i wouldnt think that would restrict power... HELP ME OUT GUYS,
thanks
thanks
thanks
thanksso started it up the other day after not driving my lnf for a day go to pull it outa the garage and it stalls. start it back up and starts idleing funny. i dont think anything of it, yesterday i get on the highway and i noticed when i let off i have a cloud of blue smoke after i let off... went to my buddys and took him for a ride and he saw the same thing every time i let off. car still has power but seems weeker then normal. some friends told me maybe pcv, but i wouldnt think that would restrict power... HELP ME OUT GUYS,
thanks
thanks
prob not the turbo bc if it was then it would smoke all the time so im thinking it might be a melted piston like my buddys but someone toold me to check my pcv anyone kn o where that is?
I'm going to bet on cracked ringlands. It should be well known by now that anything over 24psi, and you run the risk of ring end butt, and cracking the ring lands. Since you're a Trifecta dealer, it's safe to assume that your own car has a non-GM tune. Better take a good look at your tune before you stick another set of pistons in.
yes its only a 22 psi tune so idk what happened o well
just looked at the codes.... :/
P0300 multiple cyl. misfire crank speed
P0302 multiple cyl. misfire cyl. #2
P2261 induction system pulsation (prob from my tial)
P0496 leaking purge valve intank
P0497 vacuum pull down slope
took it to the dealer when i flashed it back to stock it cleared the cel they ran some evap tests and that was fine but said they wanted me to drive the car till the cel comes back on
The dealer is gonna come over hear and spend a shitload of THEIR VALUABLE TIME searching for?????
And..if they do
...how do they connect the dots with a user handle....
come on guys!
No way they're gonna make a case looking here!
If he has Trifecta...just set to stock tune and take off the mods.
And..if they do
come on guys!
And..if they do
come on guys!
And..if they do
come on guys!
i am not very satisfied with the tech he didnt really do any testing on the engine ie a compression test or leak down or anything they said to drive it till the cel turns back on... like wtf?????
UPDATE just did a dry compression test i had
#1 110
#2 80
#3 150
#4 80
#1 110
#2 80
#3 150
#4 80
patooyee
Oct 1, 2015 01:07 PM
