engine ppl in here
engine ppl in here
is it me or noone makes cams for the lnf....i wounder if crower would make a custom grind......and is the supercharger and turbo the only diff between the 2.0 motor....just want all the info.....and yes im going to do a search...thanks
before i would even go into the hardware i would get a tune considering the amount of gain you get from such little cost unless you already have and want more but the high pressure pump mite cause a little trouble. i just dont see the need for putting cams in considering the has variable valve timing and amazing gains with a tune and bolt ons.
On a stock turbo a tune is more than enough, but with the synapse gt2871 and some cams/retainers the lnf would sing quiet nicely past 7500rpm.
Maybe adding an extra lobe on the cam to increase fuel pressure would give us some extra headroom with the injectors.
A lopey cam with adjustable variable valve timing is what you want
patooyee
Oct 1, 2015 01:07 PM
