engine ppl in here
Old Jan 6, 2009 | 06:57 PM
whitebalt's Avatar
engine ppl in here
is it me or noone makes cams for the lnf....i wounder if crower would make a custom grind......and is the supercharger and turbo the only diff between the 2.0 motor....just want all the info.....and yes im going to do a search...thanks
Old Jan 6, 2009 | 07:01 PM
SUKXOST's Avatar
TONS of threads discussing LNF/LSJ differences.
Old Jan 6, 2009 | 07:04 PM
peachpuff's Avatar
The intake cam also drives the mechanical fuel pump with a 3 lobe gear, that may add some difficulty to make the cams.
Old Jan 6, 2009 | 07:08 PM
whitebalt's Avatar
http://www.gmroadster.com/index.php?...d=96&Itemid=55
this is a good write up...
Old Jan 6, 2009 | 09:22 PM
1WhiteSSTC's Avatar
u can adjust the cam timing with HP tuners, wat u need custom cams for?
Old Jan 6, 2009 | 10:18 PM
peachpuff's Avatar
More duration and lift.
Old Jan 6, 2009 | 10:31 PM
DGAF260's Avatar
before i would even go into the hardware i would get a tune considering the amount of gain you get from such little cost unless you already have and want more but the high pressure pump mite cause a little trouble. i just dont see the need for putting cams in considering the has variable valve timing and amazing gains with a tune and bolt ons.
Old Jan 6, 2009 | 11:03 PM
peachpuff's Avatar
On a stock turbo a tune is more than enough, but with the synapse gt2871 and some cams/retainers the lnf would sing quiet nicely past 7500rpm.
Maybe adding an extra lobe on the cam to increase fuel pressure would give us some extra headroom with the injectors.
A lopey cam with adjustable variable valve timing is what you want
HEATON
Oct 16, 2015 07:21 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
