Epic Day At The Dyno!!!! (331WHP/393WTQ Stock Turbo!!)
Old Aug 24, 2009 | 01:05 AM
  #51
Projekt's Avatar
thanks for all the comments guys
Old Aug 28, 2009 | 02:51 PM
  #52
madlion's Avatar
terminator i want that tune and power band.. is it hp or trifecta?
Old Aug 28, 2009 | 03:08 PM
  #53
Terminator2's Avatar
HP Tuners. My torque curve is smooth flat and broad. Broad powerband is greater than big peak numbers any day.
Old Aug 28, 2009 | 03:16 PM
  #54
06black's Avatar
Originally Posted by Projekt
So today was our local dyno day, 50 bucks for 2 pulls. First i ran my stock tune selected early in the morning..was very cold. 10 degrees cel. I turned traction control off but did not make comp mode on. i did my run at around 110 KPA and dynoed at 321 WHP (no torque because their was people waiting, didnt want to setup the coil pack thing). next run was right after..put infiniboost on..did a run..was dissapointed..ran a little under 321 WHP.
so later in the day they figured out how to attach the coil pack torque converter to my car. So after everyone else ran, i got one more attempt at the dyno.
I had my friend (kennyspec) run a data log. I turned infniboost on..and had at her...best part was when Chris the guy organizing the dyno turned to the crowd and said "he made ALOT more"
Big thanks to Trifecta Performance, as well as Motion Performance for holding the dyno daying and being so generious.
I belive these numbers put me at the highest torque on stock turbo. As well as impressive HP numbers.
(posting pics/vids now...)
so your saying that the dyno is making **** up then.....
horsepower is derived from torque, as torque is a measurable force where as HP is a work formula.
you need the force(torque) and RPM to find HP. with out a coil pack pick-up the dyno does not know the engine RPM accurately, thus you cant find accurate HP.
torque could be found off the load cell, but nothing more, and not at accurate/reputable RPM point.
you can not have power with out torque, its fact. thus i find this dyno and its numbers to be suspect of tom foolery.
how does one run the tune once, and get low numbers, then go back to run it again and make more power?
something does not compute here.
Old Aug 29, 2009 | 04:01 AM
  #55
Boosted_Cobalt09's Avatar
I wouldnt go that far. this is seriously not a safe tune to be running IMHO. they didnt get it on video but their was times where black smoke would pop out of my exhaust not to mention i have poped code p0106 (map out of range) when i get on it in 3rd/4th gear recently. I would recommend sticking with the safier LNF tune.
ive seen a few factory cars do this under load occasionally. i dont think its the tune really but i could be wrong.
Old Aug 29, 2009 | 04:10 AM
  #56
SlowBalt_06's Avatar
i'm calling bs...but thats just me..i will bet he will go to the local track and run 13.9 at best...on 10 degrees of timming....again you can make a dyno read pretty much anything you want
Old Aug 29, 2009 | 04:18 AM
  #57
steddy2112's Avatar
Oh heavens I said that once and magically my post got deleted.
Old Aug 29, 2009 | 01:08 PM
  #58
Projekt's Avatar
It was a dyno day..i wasnt the only car running..i didnt rig the dyno... i dont even know how to rig a dyno.
Go ahead..call BS..i could give 2 ***** really. i have my runs on video, i have the dyno sheets..i have the HP made by all the other cars which were all pretty much bang on.
Old Aug 30, 2009 | 06:46 PM
  #59
sstaton1983's Avatar
is the trifecta tune letting you boost such high psi?
Old Aug 30, 2009 | 07:59 PM
  #60
09CobaltSS1's Avatar
Yeah, Vince's tune tricks the ECM somehow in order to achieve higher boost than HPtuner guys can get currently.. couldn't give you the down and dirty technical jive on it, but that's more or less what he's doing..
Old Aug 30, 2009 | 11:45 PM
  #61
bamaboy22's Avatar
and its great
Old Aug 31, 2009 | 03:09 AM
  #62
mkriebs's Avatar
Its just MAP sensor rescaling. I think HPT is releasing that next... but god knows.
Old Aug 31, 2009 | 05:05 AM
  #63
YaKkO's Avatar
where are these vids?
Old Aug 31, 2009 | 09:12 AM
  #64
Not true actually. I have my overboost and underboost turned off with HPTuners and all I have to do is buy a manual boost controller and I could run that much boost, but I like my powerband.
Old Aug 31, 2009 | 12:12 PM
  #65
Projekt's Avatar
my powerband is fine. if it dropped off the map id be in trouble..but its over 300 all the way to 6500
you should try reading the entire post first.
i said they hooked it up for my final run..the run were we calculated tq. congradulations.
Old Aug 31, 2009 | 01:30 PM
  #66
Well yeah of course you can control it with a manual boost controller, but you can not through programming the ECM in HPTuner yet like trifecta currently does.. It's just that much more hardware you need, and more money needed to be spent with a manual controller install.. Definitely works no doubt though.. I'm not bashing HPTuner by any means man, you guys have obviously proven you can get some big numbers out of these cars just statin an observation about the CURRENT HPT limitations..
Old Aug 31, 2009 | 01:33 PM
  #67
mkriebs's Avatar
So, when HPT unlocks whatever tables allow us to overboost, would I be able to run a solid 24 psi to redline? None of this spiking crap. IIRC our turbo is efficient at 24 psi, right?
Old Aug 31, 2009 | 01:53 PM
  #68
madlion's Avatar
terminators powerband would own on the auto-x course. but why do you rev it to 7000rpm. its not making anymore power. I do understand that it would be beneficial to hold it out that long for the next gear but i would be afraid of NLS at 7000 rpm. you could have a nice powerband at 6700 rpm and retain the NLS, wouldnt that be more beneficial?? or do you nls at 7000 lol
Old Aug 31, 2009 | 01:59 PM
  #69
I lift when I shift and I rev higher than 6800 because my 1st and 2nd gears are over too quickly LOL. I make good power until about 7200. It drops to 300 whp at 7400.
Turbo Johnny
Feb 21, 2019 09:41 AM
Canadia
Oct 6, 2015 10:20 PM
camaromanss1992
Oct 1, 2015 10:51 PM
Cptnslo
Sep 24, 2015 09:32 AM
TylerJHowell
Sep 21, 2015 06:47 PM
