Everyone having issues with gms1 chime in!
Old Jun 28, 2010 | 02:07 PM
DoMiStIc_RuSh_06's Avatar
Arrow Everyone having issues with gms1 chime in!
Hey,
I'm trying to gather some information so I can take to my dealer about the issues I'm having with my gm stage 1. So anyone who has/ had issues with their stage 1 please post in this thread. Post the issues, what fixed it or if it remains unsolved or even what they might be able to do to fix it.
I wanna get as much info gathered for them so they can hopefully fix my car.
Thanks in advance
Old Jun 28, 2010 | 02:39 PM
PrincessTurbo's Avatar
Man a lot of people having GMS1 problems .. what I think a lot of people run into is that they get the stage 1 kit installed at some dealership by joe blow who doesn't know wtf he is doing .... 9 out of 10 techs wouldn't even be able to tell you what a intercooler is yet they can install stage kits ...
HP tuners is only 650 new ecu 200 and you don't even have to let dingle berry jones plug in a couple sensors and upload a calibration because that is just way beyond most dealers tech skills ..
What is your problem ????
Old Jun 28, 2010 | 04:20 PM
My problem is that I'm experiencing flutter from my bypas valve when the boost gauge is in vacuum, my car seems to have lost power(really it's hit and miss with the power) it was real bad a month ago and I threw a p0236 code. The last couple of days I've been getting the odd backfire while I'm on the throttle, which it's never done before. Throttle doesn't seem very responsive at times.
Old Jun 28, 2010 | 04:31 PM
Wangspeed's Avatar
Is everything else on your car stock? I've had no issues.
Old Jun 28, 2010 | 04:36 PM
ford's Avatar
flutter on GMS1 seems common. Apparently you should check the sensor on the bottom charge piping, it has a piece that needs to be trimmed in order to sit flush, it doesnt always get done.
Old Jun 28, 2010 | 04:42 PM
Stock except for chargepipes (which I've checked for leaks) and 3" turbo back.
The lower sensor never did set flush, when I seen it I trimmed the bar on the lower charge pipe. It sets flush now. Don't know if the lenght of time it wasn't flush with the pipe would have done damage to something.
Old Jun 28, 2010 | 04:53 PM
pantherqs's Avatar
Had the flutter on mine when I miswired one of the 3bar's.
Old Jun 28, 2010 | 04:57 PM
I'm gonna check the wiring on my vacation.
Old Jun 28, 2010 | 04:58 PM
umrdyldo's Avatar
mine was purely installation. Lower MAP sensor needed to be rewired and even had to order a new harness.
Was done by Reliable Chevy, Springfield MO , Service manager was Kyle.
Old Jun 28, 2010 | 05:13 PM
ford's Avatar
How exactly did they wire it wrong? Just curious, im thinking i need to go home and look at mine as it has flutter.
Old Jun 28, 2010 | 05:22 PM
umrdyldo's Avatar
Connection was loose and the harness wasn't snapping into place on mine.
The wires should technically be stripped and soldered together and wrapped.
Also, make sure to cover the wires with loom or zip tie them out of the A/C lines way.
Old Jun 28, 2010 | 05:24 PM
ford's Avatar
Gracias amigo! I thought maybe they had the wires crossed or something.
Old Jun 28, 2010 | 07:09 PM
my point exactly.. Whats a wiring diagram , is this my left or right hand ? Is that a blue wire or a green wire ..
Some dudes with the PDF from GM can install this **** better in there garage ....
Old Jun 28, 2010 | 09:12 PM
pantherqs's Avatar
Only way to go...
Old Jun 28, 2010 | 09:43 PM
Iam Broke's Avatar
...and we do.
Old Jun 28, 2010 | 10:44 PM
I need the sensors and the bung but my cheap ass wants drag radials first ..
Old Jun 29, 2010 | 08:56 AM
vahdyx's Avatar
I'm gonna get a GMS1 but I'm scared to now. Lol. I have a question for all you guys. After installation how long before you run into problems. Week , month the mnt you get on it etc.
Old Jun 29, 2010 | 09:08 AM
Terminator2's Avatar
I did this LOL. No issues with my install but I took my time and triple checked my wiring.
Old Jun 29, 2010 | 09:28 AM
Whitty's Avatar
so far so good i haven't verified the dealers install yet but it pulls strong and have had no flutter issues to date so no real reason to check it if it works
Old Jun 29, 2010 | 09:29 AM
Permafried-'s Avatar
That's what the tech did that installed mine. He looked at the crimps that came with the kit, said "I don't think I'm putting these on" and went ahead with soldering/heat shrinking/taping. He also test fit the TMAP twice to ensure he had shaven the boss down far enough for it to sit flush. So far no fluttering on mine *knock on wood*.
Old Jun 29, 2010 | 09:30 AM
Well my car acted really wierd this morning when I first started it. It starters then idled really wierd an dropped down to like 2-300rpm for a few seconds like it was gonna stall then it went back to idling like normal.... I noticed it had been backfiring at odd times, which it hasn't done before.....this ******* pos is pissing me off. The dealers are as usless as **** on a nun
Old Jun 29, 2010 | 09:36 AM
Whitty's Avatar
ur car used to backfire all the time last summer. remember when we were all headed to PPP and it sounded like gun shots and people were duckin on the streets ? i wont forget that for some time i think ur backfires have been there all along ?
Old Jun 29, 2010 | 12:22 PM
Yeah but the last few days it's all the time
Old Jun 29, 2010 | 02:29 PM
DavidW's Avatar
anyone have a picture of what has to be trimmed?
Old Jun 29, 2010 | 02:47 PM
sheldon729's Avatar
Check the vacuum tank below the intake manifold for crackes and leaks.
