EXEDY Hyper Single install!!!!!!!!!!!!
Old Jun 3, 2009 | 03:49 PM
Terminator2's Avatar
Originally Posted by steddy2112
Overall the stock clutch is strong though...it is too light though...
Yes it is, I hate the lack of feel it has. It is numb as hell and way too light.
ebristol's Avatar
Originally Posted by 06_SIC_SS
i was thinking about the exedy single...how is the driveability on it though? is it real smooth or is it more of a drag clutch which can make it real tough to shift...
I have on in my LSJ. I have never driven a car with an aftermarket clutch but it does take some getting used to.
Old Jun 3, 2009 | 03:50 PM
steddy2112's Avatar
Get a HyperSingle
Old Jun 3, 2009 | 03:51 PM
Get a HyperSingle
Soon.
Old Jun 3, 2009 | 03:52 PM
steddy2112's Avatar
Soon.
Old Jun 3, 2009 | 03:53 PM
06_SIC_SS's Avatar
k...i figured it would feel a little bit different but i just wanted to make sure it wasnt a pain in the ass to drive cuz my buddy has an srt 4 with an aftermarket clutch and u literally have to yank the **** out of the shifter to get it in gear...
Old Jun 3, 2009 | 03:54 PM
steddy2112's Avatar
In THAT aspect, it actually shifts easier.
where do you get these images? How is the feel and takeup when launching it and shifting?
06_SIC_SS's Avatar
good..thats what my worry was about
Old Jun 3, 2009 | 03:57 PM
steddy2112's Avatar
I can't leave too aggressively yet because I need 500 miles before I can go completely Steddy on it, but from what I feel...retarded good. Take up is very progressive and smooth. Shifting is almost always rewarded with a smooth foot...whereas the stock TC clutch will make a 30 year stick veteran look like he is taking his driving test, rollin on ecstasy, and when it is time, this thing has no nonsense grip. I will be limited to the amount of tire I have
With the lighter flywheel it feels like I have a shorter final drive. Car spins up A **** ton quicker.
Old Jun 3, 2009 | 03:59 PM
  #36
06_SIC_SS's Avatar
makes me wanna purchase mine right this second lol
Old Jun 3, 2009 | 04:00 PM
  #37
steddy2112's Avatar
Old Jun 3, 2009 | 04:01 PM
  #38
06_SIC_SS's Avatar
lol where do u find this ****..
  #39
~Mike~'s Avatar
so i checked the page and nobody answered it...what's the HP rating on the hyper single? I saw someone say that there's guys runnin it with high HP, but what is that "high HP"?
Old Jun 3, 2009 | 04:02 PM
  #40
Thank you for saying that. All my cars have been sticks and this car is the hardest car to drive smoothly. Glad replacing the clutch with a better one can help with feel and takeup. Stock clutch sucks. I know it will not hold up once I start autocrossing this thing.
Old Jun 3, 2009 | 04:03 PM
  #41
steddy2112's Avatar
Clutches aren't rated in HP...but I believe 06blackg85ss is running a hypersingle on his set up.
Not many people make more power than him
Old Jun 3, 2009 | 04:05 PM
  #42
Projekt's Avatar
Glad to see this works.
Old Jun 3, 2009 | 04:06 PM
  #43
~Mike~'s Avatar
well I know their not rated in HP, i was more referring to how much HP can it handle before it starts slipping? My goal is to hit 400+ and I want a clutch that's going to be able to hold it
Old Jun 3, 2009 | 04:08 PM
  #44
steddy2112's Avatar
Torque is what makes clutches slip.
Not HP.
Exedy says 'generally twice as much as stock' on their website
If what is said is true about the Hypersingle...that is a decent chunk of power.
Old Jun 3, 2009 | 04:16 PM
  #45
~Mike~'s Avatar
Not HP.
well game on then!
Old Jun 3, 2009 | 04:46 PM
  #46
BartSS's Avatar
Stupid question but this will fit my hhr right?
Old Jun 3, 2009 | 04:59 PM
  #47
PimpLay2's Avatar
i needs one
Old Jun 3, 2009 | 05:02 PM
  #48
steddy2112's Avatar
I don't see why not, as far as I know they both use the same powertrain
Old Jun 3, 2009 | 06:39 PM
  #49
BartSS's Avatar
Cool 1050 is my price on it
Old Jun 3, 2009 | 10:38 PM
  #50
Cyrusthevirus's Avatar
Not sure which one to go by lol, alot of the sites i checked stated around 350 range for tq
One site states
"Part Number : Exedy GH02SD
Application : Saturn Ion RED LINE 2004-2006 2
Notes :
Torque Capacity :330 Ft/Lbs
Exedy Stage 3 Hyper Single Clutch Kit
Recommended for Street, Race, Circuit, Drift and Rally
All Exedy Hyper Single Clutches comes with lightweight flywheels and 6 puck cerametallic facing, Spring Centered Damper Assembly. Thje disc is generally smaller and thinner than the OEM discs, made for lower inertia and therefore quicker shifting and less wear and tear on transmission synchroes. The higher clamp load and cerametallic frinction facings give approximately twice the holding torque of the OEM clutch and generally higher than other single plate clutches.
As with all cerametallic clutches, the street drivablity may be marginal due to chattering and harsh engagement characterstics. Approx HP capacity is upto 550 HP.
2nd site states
Part # Description Price
EXD-GH02SD Exedy GH02SD Cobalt SS & Ion Redline GM 2.0 S/C Ecotec Hyper Single Disc Clutch & Flywheel Set
"These clutches come as a set which includes a chrome moly steel flywheel, a single disc multi-puck cerametallic clutch, and a forged aluminum pressure plate. These are direct bolt in units. Remove your old clutch set and flywheel and bolt the Exedy unit in. You will use your own stock release bearing. Weighs up to 14-lbs. less than stock! Torque Capacity is 442 Lbs./Ft.
3rd site
"Hyper Single
GH02SD by Exedy Racing Clutch $1,521.45 $1,182.29
Hyper Single
Single; Ceramic; Sprung Center Disc; 225mm/PUSH TYPE/14T / 25 Spline; Wheel Torque Rating 358 lbs./ft.;
