Exhaust/DP ?
Old Aug 2, 2009 | 01:45 PM
09SSbalt's Avatar
Exhaust/DP ?
Will the catted ZZP downpipe bolt right up to a hahn cat-back exhaust just fine? I have the cat-back, just wanting to see if that dp would work or if I should order hahn's.
Old Aug 2, 2009 | 01:55 PM
09CobaltSS1's Avatar
As long as the dp is catted there should be no fit issues.. You may run into fit issues running a catless dp depending on a few things, but catted should fit fine..
Old Aug 2, 2009 | 11:56 PM
09SSbalt's Avatar
So when you put an aftermarket dp on will the bolts work thats already holding it on or do you have to order them?
Old Aug 3, 2009 | 12:23 PM
Should bolt right up with relatively no issues.. There's also a slight risk of fit issues when going aftermarket, but overall everything should bolt right up..
Joe Schulte
Sep 26, 2010 08:24 PM
