A/F ratio problem
Old Nov 23, 2010 | 09:18 PM
maddmojo15's Avatar
Angry A/F ratio problem
have a 2010 tc ss w/ gms1, hahn intake, dejon cp w/ hks bov. the weather is about 33-40 degrees where im at. recently noticed the car would jerk oddly once or twice after shifting into gears. check my a/f ratio guage and the needle is jumping from 12 to 16 and sometimes 18 after shifting into gear, espically 2-4 gear. the issue has been going on for about 5 days now and i want to get your input on what it maybe or how i can reslove it. thanks for any help & advice
Old Nov 23, 2010 | 09:23 PM
09BlueBaltSS's Avatar
12 a/f is really rich for gms1 and its normal to swing way lean during shifts
Old Nov 23, 2010 | 09:26 PM
blrt's Avatar
Maybe a fried front 02 sensor? Just a guess..
Old Nov 23, 2010 | 09:33 PM
Chevycobaltss3's Avatar
Take alk ure aftermarjet off and put stockr **** back on if ure not tuned for it
Old Nov 23, 2010 | 09:35 PM
Totally missed the bov. Yup that will do it
Old Nov 23, 2010 | 09:36 PM
maddmojo15's Avatar
take all the aftermarket stuff off or just the bov?
Old Nov 23, 2010 | 09:37 PM
bov. Get a block off plate. Do you still have the factory bpv or did you block that off?
Old Nov 23, 2010 | 09:38 PM
maddmojo15's Avatar
ok so take the bov off until i can get a tune for the bov? is it ok to leave the bov discennected in place of the cp so i can at least keep the piping?
Old Nov 23, 2010 | 09:40 PM
maddmojo15's Avatar
i didnt buy the block off plate... i went thru the dejon pipe thread install and just followed all the instructions & bypassed it i believe
Old Nov 23, 2010 | 09:45 PM
ronn's Avatar
You would think it would run pig rich with BOV not tuned in. Metered air vanishes...so ECU thinks there's more air than there really is?
Old Nov 23, 2010 | 09:49 PM
OP you should have an engine light on. Correct? How long have you had the bov on the car?
Old Nov 23, 2010 | 09:51 PM
05Slowline's Avatar
maybe putting a bov on a recirc car???
Old Nov 23, 2010 | 09:55 PM
maddmojo15's Avatar
yes.. cel has beeen on for 4 days and the bov has been on for maybe a week & half... do u suggest just removing the vac line from the bov so its not opperable?
Old Nov 23, 2010 | 10:08 PM
AndrewSS/TC's Avatar
I'm stock and mine goes as low as 11
Old Nov 23, 2010 | 10:12 PM
maddmojo15's Avatar
its weird though... ill be cruising at 30 or 40 and the car will pull for a sec or two w/o me giving it any more gas
Old Nov 23, 2010 | 10:13 PM
05Slowline's Avatar
bov blew the welds on the im
Old Nov 23, 2010 | 10:19 PM
maddmojo15's Avatar
for now should i just diconnect bov?
Old Nov 23, 2010 | 10:22 PM
Is the stock bypass valve still there and hooked up?
Old Nov 23, 2010 | 10:36 PM
maddmojo15's Avatar
the bpv is still there & hooked up
Old Nov 24, 2010 | 12:12 AM
tomj77's Avatar
take ur foot off the gas once, it will go up to 30. lol i dont think there is a problem, when u lift ur foot off the gas it will go lean. drive down the highway, giver a little and take ur foot all the way off the gas, it will go up to 30. its normal
Old Nov 24, 2010 | 01:36 AM
maddmojo15's Avatar
what will go up to 30?
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
