A/F Ratios
Old May 12, 2011 | 12:26 AM
Kbbalt's Avatar
A/F Ratios
I just got my 08 balt, last night...
It came with a Aeroforce, I was watching it and the A/F ratio is between 14 and 16 while driving and i've seen it jump up to 29!
What is the A/f Of these cars?
Old May 12, 2011 | 03:24 AM
evil 2.0's Avatar
that sound about right for a cruise 55 60mph what is it at wot
Old May 12, 2011 | 03:26 AM
HunterKiller89's Avatar
it should be trying t stay at 14.7, so bouncing around that number +/- 1.5 is normal given varying TPS% and RPM. 23 would be either a very sudden throttle change (should just blip to 23, not hold it there) or DFCO (in which case it will hold there). All are normal...
Old May 12, 2011 | 07:15 AM
Kbbalt's Avatar
Sweet Thanks guys, just didnt know. I drove a charged cavalier before this. So im was unsure.
Old May 12, 2011 | 05:40 PM
peachpuff's Avatar
It only goes to 29 afr when you let off the throttle since the injectors shut off during dfco.
Old May 15, 2011 | 01:46 PM
Kbbalt's Avatar
Ok after futher examination...in 5th gear with no throttle. Equals a a/f ration of a steady 29
Old May 15, 2011 | 02:20 PM
5th gear with no throttle? or 5th gear with cruising throttle? Either way, that would be an issue.
Old May 15, 2011 | 03:08 PM
YelloEye's Avatar
Car will read up to 29.4 due to DFCO.
Old May 16, 2011 | 02:13 AM
this. not sure why i said it doesnt matter last night (too many drinks?). If there was throttle, thats waaaay too lean. if not, IE coasting down, then its normal
Old May 16, 2011 | 10:34 AM
BooSSted's Avatar
If you were on the gas and hit 29:1 a/f. You wouldn't need a gauge to tell you that something was seriously wrong.
OP, It's all good. Monitor a/f under WOT and it should be in the 12.0 area on a TC.
Old May 16, 2011 | 08:01 PM
Kbbalt's Avatar
Oh ok yea under throttle its normal but when I was coasting I was like WTF 29??? Thanks guys
Old May 16, 2011 | 08:11 PM
09CobaltSS1's Avatar
Coasting (foot off gas)in 5th gear anywhere above 2000rpm will put the car into DFCO (decel fuel cut-off) which, as stated, will register VERY lean on a wideband. Anything over 2500rpm in 1st-4th gear while coasting will again put the car into DFCO. These very lean readings during DFCO are absolutely normal, will not harm the vehicle and are designed for fuel conservation
DocSvensk
Sep 27, 2015 02:24 PM
polo708
Jul 10, 2006 03:56 PM
Twincharged
Feb 1, 2006 09:12 AM
silverSS
Jan 17, 2006 07:46 AM
Jmc007
Dec 4, 2005 05:22 PM
