Factory Wideband Tap
Old Jan 22, 2023 | 12:04 AM
audisfelicia's Avatar
Is there are easy place to tap in to the factory wideband to add a gauge? I have the RPD already, just need the location of where I can find the AFR signal from the factory wideband.
Old Jan 23, 2023 | 03:15 PM
bump 36 views no replies
Old Jan 25, 2023 | 10:32 AM
Tdubbs's Avatar
If I'm reading this right you have an RPD, but are looking to add an external AFR gauge as well, correct?
I honestly don't know where an easy place to tap the signal would be, but the post below might help. It at least gives the pinouts at the PCM for the sensor wires, so you may be able to piggyback there.
https://www.cobaltss.net/forums/2-0l...e-u-go-237786/
Old Jan 31, 2023 | 07:12 PM
I found out that tapping into a wideband can screw with resistances and make the signal going to the ECM wrong. Decided to use the RPD for AFR and get an oil pressure sensor installed, thanks!
Old Feb 9, 2023 | 10:38 PM
tomj77's Avatar
Buy a scan gauge that plugs into ur OBD2 port and select ur O2. Don't be tapping into it and mess things up when u can just get a scan gauge
coltsfan14
Jan 11, 2011 09:40 AM
*S!CC_R@c!NG_TURTL3*
Nitrous Oxide
Oct 1, 2009 08:01 PM
rrutter81
Jun 13, 2008 01:03 PM
hispano1
Jan 21, 2007 12:20 AM
