finally dynoed on the efr
So i finally had a chance to dyno the car today and i was more than happy with the results.....
Thanks to 09cobaltss1 for the tune car feels great now... my 1st pull was 380 whp with 350ish tq then he adjusted a couple things on the dyno and we got this..... I was really happy with 380 but he knew we can get to 400 no prob so i let him work his magic and 1 pull later we get this
efr cobalt ss dyno pull - YouTube
410whp and 380tq!!!
410whp and 380tq!!!
Well he was running a conservative tune at the time so im assuming he made it more aggressive, added a little timing and boost and gained an extra 30 hp and tq... great graph by the way nice and smooth... we still need to see if we can adjust the wastegate but this is perfect for me right now.. Im more than happy with how the car turned out. exactly wat i wanted
Pump gas with meth, but hes not going to crazy, im not trying to get that much out of the car now, its my daily driver that i use every day i dont want to f.uck up my tranny, so hes just doin wat i ask of him haha. but he just wanted to break 400 on my car and he did it easy. after the dyno we brought it back down a little bit lol
At the moment the tune still isn't all out BUT his wastegate does need to be adjusted because I can't get anything more than 25.5psi out of it so there is still more power to be made for sure, especially if he ever decides to install valve springs.
I'm sure there will be a few people with something to say about the "slow spool time" of course though. Those are also the same people that don't understand the idea of boost ramp in and seem to be busting James' ***** about the slow spool time as well..
So I'm kinda confused about your post. Is 411whp/380wtrq disappointing for what you were expecting or right on? lol
Yeah like ixxgh0stxxi said, it's on pump with meth. There is most definitely power left on the table at this point but he very wisely wants to keep in conservative to have a solid and reliable street monster.
Take a pic of the power graph itself and post it my man.
No no.. The turbo can and will spool up almost as fast as the k04 but only IF made to do so. Making a 6258 spool right to 25psi at 3k is just not a good idea imo. You're just asking for issues all around. Plus there's something to be said about making "usable" power
Great useable power band right there. I personally believe all tuned stock turbo cars should have some form of a boost ramp to get rid of that terrible spike in the midrange.... It's how I've always done it. I don't think it should be any different with a fast spooling aftermarket setup either. Nice work gents.
Happy to see SAE numbers too
Does he have 3bars by chance? If so good if not are you guys reading boost by his boost gauge? And also these aren't bad numbers. I'd say decent considering the factoring of the turbos size. Good job
I have a question about the fueling. Is it normally that lean with 93/meth? I know on E85 I am pretty lean but I am not as lean as he is (just by looking).
Here is my sheet on 24.5psi E47
Yeah the dyno wideband was registering pretty lean for whatever reason, but the car wb in my logs from the dyno pulls were showing the commanded .86 lambda I have it set for. His wb is brand new as well so I'm pretty confident that the logs are accurate.
I think you are doin a good job..The numbers seem about right, but all dynos are different like we all know, and yours may be reading a little lower than the next one...Since he is on E, is it possible to be at the 450whp mark safely??? Hows the driveabilty and power to you?
oh, i thought he was on e...great numbers then....i've noticed that most are getting the upgraded map sensors when doing a turbo swap, and u explained why above...thanks..lol
I thought about doing one of the pulls in 4th just to see if more power could be made by loading up the engine more but said screw it. How much power are you putting down with your treadstone setup again?
