finally made my mind up
Old Jun 19, 2011 | 05:26 PM
jaygo7007's Avatar
Cool finally made my mind up
been thinking for a while on either e85 or meth.... and decided to go the the corn!!!
so is there anything i might need besides the tune??
mods in sig
Old Jun 19, 2011 | 05:31 PM
BLAZIN07SS's Avatar
I'm too JDM for you
You more than likely are not going to be able to run full e85, probably a e47 or e60 blend
Old Jun 19, 2011 | 05:38 PM
jaygo7007's Avatar
what does a e47 or e60 blend consist of???
and would i need any other mods
Old Jun 19, 2011 | 05:53 PM
paintballerr78's Avatar
you can run straight e30 if you have it around you. e47 and e67 is basically e85 mixed with different amounts of 93 if im right dont quote me on this
Old Jun 19, 2011 | 05:59 PM
jaygo7007's Avatar
all we have in houston is 87 89 and 93 and some e85
Old Jun 19, 2011 | 06:01 PM
RYRO14's Avatar
Yeah this car doesnt like full E-85, the most power is made on E-47. E-47 is a 1:1 mix of 93 octane E-10 and E-85.
Old Jun 19, 2011 | 06:02 PM
ya i think u just mix e85 with 93 to get a different eblend
Old Jun 19, 2011 | 06:04 PM
slvr 04 rl's Avatar
why are you asking this kind of questions. laser racer could have answered this for you since you will have to go back for a retune with him.
jaygo7007's Avatar
if i was to do half 93, half e85 mix would it have to be exact when pumping
Old Jun 19, 2011 | 06:07 PM
BLAZIN07SS's Avatar
I'm too JDM for you
Well obviously it has to be close. Just do 4 gallons 93 and 4 gallons of e85. Simplest way to do it
Old Jun 19, 2011 | 06:08 PM
RYRO14's Avatar
It wouldnt have to be exact, but pretty close to a 1:1 mix. When filling, just drive around a little so it can mix before you get on it.
Old Jun 19, 2011 | 06:09 PM
jaygo7007's Avatar
last time i talked to him i thought he said i could run full e,,now since i posted this someone said the car doesnt like full e, so it doesnt hurt to ask and get more opinions does it
Old Jun 19, 2011 | 06:12 PM
jaygo7007's Avatar
gotcha
Old Jun 19, 2011 | 06:17 PM
BLAZIN07SS's Avatar
I'm too JDM for you
What happens on full e85 is it pops a low rail pressure code in fourth gear and puts the car into engine power reduced
Old Jun 19, 2011 | 06:19 PM
jaygo7007's Avatar
and thats never good! thanks for the heads up
Old Jun 19, 2011 | 11:54 PM
09BlueBaltSS's Avatar
E60. Run the car so its in between 1/8-1/4 then put 3gal 93 and 6gal E85. That will put you right at 7/8-full. You will go through the fuel faster though which will offset the couple dollars you save per fill up. So in short you will be paying about the same on a monthly basis for fuel, just having more fun
Old Jun 20, 2011 | 12:11 AM
austinss's Avatar
I'm not trying to thread jack here but..anyone know what kind of gains can be had with the same mods OP has but with meth?
Old Jun 26, 2011 | 05:15 PM
jaygo7007's Avatar
i would like to know the same. but i dont wanna take a chance on getting a clogged line and something messes up. so thats why i chose e, but e isnt everywhere thats the downfall
a off the topc question would it be better to run a straight pipe from the turbo back or add a muffler at the end. i had a muffler on but took it off now i kinda wanna put it back on lol
Old Jun 26, 2011 | 05:31 PM
Turbo'dSS's Avatar
Ive never had any issues with full e85. no codes poped or anything, and ive beat on it pretty good. Ive heard that it will damage your fuel pump in the long run though. ill probably switch back to HPT from trifecta and go 1:1 e85/91
Old Jun 26, 2011 | 07:01 PM
MS3 2 SSTC's Avatar
No issues on full E85 yet.
Old Jun 26, 2011 | 07:12 PM
80vetteL82's Avatar
Id be interested in jumping on board and trying an ethanol blend, but unfortunately theres only like 2 stations in MA that sell it. Also, I read in some thread on here recently that youll suffer a pretty significant hit in MPG on a high ethanol blend. Is this true? If so, do the benefits of the switch out weigh the loss in economy...? I forget where the thread was, but the person said they went from like 26mpg to 19-20....? Seems like a pretty BIG drop...?
Old Jun 26, 2011 | 07:25 PM
jaygo7007's Avatar
hell i only get 23 mpg... my car sucks
Old Jun 26, 2011 | 08:11 PM
Turbo'dSS's Avatar
mpg does go down quite noticeably. but idc. lol!
Old Jun 26, 2011 | 08:47 PM
E85 has a couple things against it. Ethanol is an oxidizer, it attracts water, and it doesnt have the same lubrication properties that regular gas has. Go to your local auto parts store and pick up a bottle of E85 fuel treatment. Its made by Redline or Lucas Oils. It will counteract those possible problems. 2oz per fill up
I havent had a chance to find highway mileage but in the city I was averaging ~21mpg now I get ~18mpg. The only time it really sucks fuel is wot. I did a pull from 40-130 and I used about 0.3 gallons(via HPT) in what took about 13 seconds
06MetallicBalt
Jul 20, 2025 08:47 PM
Oct 20, 2015 09:56 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Trav3480
Oct 1, 2015 08:17 PM
Trav3480
Sep 28, 2015 02:46 PM
