Flutter?
Old Sep 21, 2016 | 08:27 AM
Canadia's Avatar
Flutter?
Hey all, I've developed a flutter if I let off the throttle very lightly, if I give it more gas before I let off it will vent normally still. Does not do this in boost or WOT as far as I can tell. I've taken the forge BPV off and cleaned/lubed it and that hasn't solved the issue. Yes I installed the piston facing downward and yes the nipple and vac lines are facing upwards. I noticed I have the yellow spring installed in it and I've read people saying green is the way to go - but where I've run this setup fine for the last 2 years I don't know why I would need to change the spring rate. It's always done a slight flutter every now and then but never this bad.
Any ideas? (Sorry if link isn't embedded I'm doing this from phone)
Old Sep 21, 2016 | 10:45 AM
tomj77's Avatar
U still have a vac tank? If u do its probably going out, if u dont its probably ur solinoid going out or sticking.
Old Sep 21, 2016 | 03:53 PM
Canadia's Avatar
Bpv or boost solenoid on the turbo or intake mani. We just bypassed the vac tank and I thought it fixed it but it didn't.
Old Sep 21, 2016 | 04:16 PM
user 72239's Avatar
Sounds normal to me. My yellow BPV fluttered the entire time I had it.
it wont hurt anything
Old Sep 21, 2016 | 08:26 PM
tomj77's Avatar
Bypassing the tank will cause slight flutter,. Cause vac isnt as fast. Its fine. Live with it like the rest of us. Put in green spring as well. It will help
Old Sep 22, 2016 | 02:56 PM
RYRO14's Avatar
Im having this issue well.... It started happening right after I installed 3 Bar MAP sensors.
Franken
Oct 6, 2016 12:24 PM
boostbalt
Sep 29, 2016 11:46 AM
royce777
13
Sep 23, 2016 08:45 AM
Evilfrog
Sep 16, 2016 10:58 AM
Crav3
Sep 15, 2016 06:08 PM
