Forge BPV spring question
Old Feb 2, 2013 | 01:53 AM
Ltguy's Avatar
Just a quick question on the Forge BPV.
Says the green spring is pre-installed but comes with a yellow spring to be used with higher boost applications. What exactly would you consider higher boost? GMS1 or like a 20 psi tune? or is the yellow more for you guys running like 25+ ???
If anyone has it I wouldn't mind your opinion on it either
Thanks!
Old Feb 2, 2013 | 01:57 AM
BlackARCA06's Avatar
I was tuned at 24psi and was running the yellow spring, but experienced a CEL and some flutter and went back to the green spring and all was good. Then I sold the Forge and got a BOV. lol IMO just use the green spring, some guys use the yellow...just see wht your car likes.
Old Feb 2, 2013 | 06:42 AM
Aleksey's Avatar
No offense but if you used search you'd see there's about 100 of these threads.
I use green with 20+ tune and no issues.
Old Feb 2, 2013 | 10:02 AM
Sox-Fan's Avatar
Got Brakes?
25 lb tune. Green spring.
Old Feb 2, 2013 | 10:17 AM
user 72239's Avatar
24 lb tune, green spring. I tried yellow but got a CEL for p2261 and horrible flutter. back to green and it works better
Old Feb 2, 2013 | 11:05 AM
Same exact problem I had.
Old Feb 2, 2013 | 01:08 PM
Ltguy's Avatar
Thanks guys.
And I did use search like I always do, it came up with nothing but for sale adds and reviews, none of which answered my question. Unfortunately the nice thing about the site having so much knowledge is the search bar does t work as well... No offense but I'm not going to search through hundreds of posts when there is plenty of nice people with knowledge for a quick answer.
Old Feb 2, 2013 | 01:22 PM
Sox-Fan's Avatar
Got Brakes?
don't use the search here. it sucks. use google
site:<site.com> <search words>
site:cobaltss.net forge bypass valve spring
Old Feb 2, 2013 | 02:11 PM
Miltown SS's Avatar
I use the yellow on GMS1 and it has worked well, seems to hold boost better.
Old Feb 2, 2013 | 02:33 PM
09CobaltSS1's Avatar
Stick with the green spring. In my own experiences with my car and quite a few other lnf's I have worked on there is nothing but headaches with flutter in particular when using the yellow spring.
Old Feb 2, 2013 | 03:44 PM
kzak104's Avatar
i use green no problems,
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
Sep 27, 2015 08:53 PM
