Forge BPV VTA
Old Feb 28, 2013 | 12:16 PM
vahdyx's Avatar
Originally Posted by Cavalierssr
Mine made the same noise as yours after 16lbs of boost. It's normal - you can even hear the turbo make that same noise if you have a K&N intake and the stock BPV. You have to know what you're listening for though.
I have guess I never noticed with the stock BPV. I'll have to check on that too at a later date. Right now I'm gonna try greasing it up.
I have the K&N SRI so I want to think it's normal, but a LARGE part of me wants to be safe and be sure.
**edit**
I think you might be right. As I test my newly lubed valve I notice that it still blows off smoothly but makes that barking noise still. It's like two Independent noises.
So K&N norm?
I guess I will have to put the stock one on and compare sounds.
Old Mar 2, 2013 | 08:02 PM
vahdyx's Avatar
I put my stock bypass valve in and I'm experiencing no surge like i did with the Forge VTA. So without a doubt this forge bypass valve is causing compressor surge. No compressor surge from any level of boost with stock bypass.
I am gonna attempt a refund.
A buddy of mine suggested I cut the spring to let it open more, but I'm not into doing that.
Old Mar 2, 2013 | 08:43 PM
ShawnW117's Avatar
**edit**
So K&N norm?
Mine makes a kind of barking noise at higher boost levels, usually at wot over 20 psi, but it doesn't sound like what you posted. Definitely doesn't happen at 10 psi.
Old Mar 3, 2013 | 12:04 AM
vahdyx's Avatar
Do you have the Forge VTA Bypass valve?
Old Mar 3, 2013 | 10:57 AM
vahdyx's Avatar
I'm wondering if the higher back pressure of the K04+ is causing my surge with this VTA BPV, because the local guy that has the exact same VTA Bypass valve is not having any issues anymore.
Would opening up my wastegate a little more help this problem? I really enjoy the sound of the VTA Bypass, but I won't put it on if it's causing surge.
Old Mar 3, 2013 | 11:17 AM
ShawnW117's Avatar
Yeah I have the VTA forge with a maf relocate and hp tuned
Old Mar 3, 2013 | 11:31 AM
tomj77's Avatar
thats surge, let me ask u a question, are u doing vacuum tank bypass? if so, thats ur problem
Old Mar 3, 2013 | 11:35 AM
vahdyx's Avatar
Seeing how I don't know what that is, I'm gonna have to say no I don't think I'm doing that vacuum tank bypass.
To illustrate how I had it installed, I put it on just like the stock bypass valve is installed. No other modifications were made.
Old Mar 3, 2013 | 11:44 AM
tomj77's Avatar
try using pulling the line off the manifold and hooking bpv stright to manifold, if that fixes it, ill show u how to bypass vacuum tank
Old Mar 3, 2013 | 01:18 PM
YelloEye's Avatar
negative. this is different than the other Forge. There is no notch or anything to identify which way it went.
I resolved this issue by unkinking some vacuum lines. I dont get anymore surge
This slot opening isn't on the back side? Picture is of the normal BPV, can't seem to find any of the VTA version.
Old Mar 3, 2013 | 01:45 PM
  #36
vahdyx's Avatar
The VTA version doesn't look like that. I'm cleaning the VTA version and I'll make a video of it. One sec...
Everyone keeps thinking it's the same, but it's not.
It'll be good so people can see how it works too.
Old Mar 3, 2013 | 01:47 PM
  #37
Omiotek's Avatar
if its venting to atmohphere it wouldnt work like the recirculating one. the slots there to allow air back in as the piston moves.
Old Mar 3, 2013 | 02:29 PM
  #38
vahdyx's Avatar
My video is processing right now, apparently made the mistake of making it 1080p and it's gonna take 15 minutes to process.
I have it broken down and I reassemble it and it should give more savvy people an idea how it works such as yourself.
Like I said something is up with my particular set up because a local SS/TC owner (Leemanfor) is not getting any surge and apparently another person here isn't either.
The only difference I can make out is I'm using a K04+ (or WR-1). When I had the regular version of the Forge BPV on my stock turbo I used the yellow spring and no surge happened, but the moment I switched to the K04+ I started to get surge, then I switched to green and it went away, so without any real knowledge of the situation, I just assume that maybe this bypass valve is too much for my turbo (K04+). The yellow spring appeared to be too much for it as well... so I assumed anyway.
I'll have the video up within the hour for those interested
Old Mar 3, 2013 | 02:39 PM
  #39
vahdyx's Avatar
Here's the link to that video. It'll be up in a few minutes.
Old Mar 3, 2013 | 04:58 PM
  #40
YelloEye's Avatar
Forge VTA Bypass Valve Assembly - YouTube
Ah! Thank you sir! That clears things up a bit.
Old Mar 3, 2013 | 06:03 PM
  #41
vahdyx's Avatar
No problem, sorry about the jumpiness of it, that's what I get for using 2 anti-shake 'enhancements' one on my mac and one via youtube. It looks kind of creepy.
Old Mar 4, 2013 | 02:08 PM
  #42
user 72239's Avatar
dude my piston was really lubed up when i got it. had a bunch of red lube on it. It was still a bit hard to push up and down. so far no surge
Old Sep 20, 2013 | 02:17 PM
  #43
80vetteL82's Avatar
Was there ever any outcome with this? I just installed my VTA Forge and I get some "flutter" noise. For me it happens more at lower boost, and actually even in vacuum if I let off anywhere from 10inHg - 0psi, then between 0psi - 10psi. On the boost side if I'm accelerating harder (boosting about 10psi or more) it doesnt do it. I'm still waiting for my updated Trifecta ECP tune, so I'm not sure if that could be causing it. I haven't changed springs, it came with the green one in it I believe. So what did you guys finally figure out? Green or yellow spring? I'm GMS1, K&N SRI, Catless DP, Trifecta, and the Forge VTA.
Old Sep 24, 2013 | 09:04 AM
  #44
user 72239's Avatar
ok.
First off, I used the green spring for awhile but it wasn't holding boost well. I swapped to the Yellow spring and had flutter. I had to lube the piston up a bit, so i went and bought Mobil 1 lubricant and it helped a bit. However, with the yellow spring you will get flutter at around 10 psi.
I made a video and sent it to Forge and their Engineer replied telling me it was turbo flutter, and nothing to worry about. Even stock BPV cars have turbo flutter you just cant hear it well. He showed me a video of real "surge" which, was a video of a Skyline, and it didn't sound anything like surge. I actually like the flutter sound.
I have been running the yellow spring for 6 months and I have no problem. Holds 26 psi and I have no oil leaks from the turbo, checked the shaft last week when I was cleaning the intake and there is no shaft play
Old Sep 24, 2013 | 01:23 PM
  #45
tomj77's Avatar
Turbo flutter can still decrease the life of the turbo, ur basically having ur turbo spin one way and then a rush of air coming back trying to force it to spin the other way. In the long run, that ain't good. And that's bs that the bpv has flutter it doesn't at all unless u boost up in a high gear and it doesn't have enough vac to open. Normal driving there is 0, in fact I think it stays open for to long, at least 2 seconds of blowoff and u can still hear a tapering off blowoff till u hit the gas and it closes.
Old Sep 24, 2013 | 01:36 PM
  #46
06RYSS's Avatar
good info. i'm thinking about picking this piece up soon.
Old Sep 30, 2013 | 09:51 AM
  #47
user 72239's Avatar
This is false, it doesn't make the turbo blades spin backwards. the noise is the turbo blades chopping the air. the force required to stop and make the blades turn backwards would need to be considerable considering they are spinning extremely fast.
Flutter does not decrease the life of the turbo. Surge does.
I have ran this thing for almost 10 months with the flutter all the time and I checked my turbo about a month ago and everything is fine, it boots to 26 psi no problem and has no shaft play.
my buddies Saab 9-3 flutters with stock bpv, you can hear it now that he put an intake on it.
Old Oct 3, 2013 | 09:32 AM
  #48
willdrew's Avatar
yea ive ran mine for about 5 months now and no problems here.
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
Sep 27, 2015 08:53 PM
