Forge Diverter Valve Questions ??
Old May 23, 2012 | 09:25 PM
QuickSilver_SS's Avatar
With only having my tc for a few weeks. I have been trying to read as much as I can understand. Which aint much !! I was thinj=king of picking up a Forge Diverter Valve from modern performance. There pretty resonably priced. And look simple to install. However , I have a few questions. I take it that when they call it a diverter valve. thats the same thing as a bpv ? Alos , I have heard that the nosie that comes with the forge is only slightly louder then stock. And that to hear it really well you should have an intake ? Or at least a cold side pipe. Is that correct ? And lastly. IF I did get the forge unit. Will it cause any driveability issues at all ? And will my car have to be retuned for the forge ? I have rea that our cars use a re-circulating system for the turbo an some bov can only really be used if you retune for them. Other then this forge bpv I may some day get an intake and possibly gms1. Thats all I will probably ever do to my balt.
Old May 23, 2012 | 09:28 PM
BPacak's Avatar
Vtec Rep
no you do not need one they are just stronger and wont tear like the stock one can.
if you want a really good sound get the forge bpv and a k&n sri, wont even need a tune but its the smart thing to do.
Old May 23, 2012 | 09:52 PM
09TcSedan's Avatar
k&N+STOCK BPV= awesome panada sneeze.
Old May 24, 2012 | 07:25 AM
Isn't the Forge Diverter valve just a different name for a bpv ? I thoought they were one in the same thing. If so , then get the Forge Diverter valve and an intake ?
Old May 24, 2012 | 07:27 AM
Panda sneeze !! That would be okay with me. Any noise would be better then the whisper quiet stock trim.
Old May 24, 2012 | 03:52 PM
BPacak's Avatar
Vtec Rep
yeah the forge valve is a bpv
Old May 24, 2012 | 05:35 PM
CudaJoe's Avatar
Get the intake, get the Forge diverter valve. done.
Old May 24, 2012 | 08:23 PM
Will I be okay with NO tune. Will I have any driveability issues ? Because there are no tuners any where even remotly close to me. The nearst ine is probably close to a 4 to 5 hour drive. So what intake is the best with no driving issues. With no tune ?
P.s - I did read the intake thread. But theres too much info in there to sort through !!
Old May 24, 2012 | 08:27 PM
Sox-Fan's Avatar
Got Brakes?
You can be tuned remotely, FYI.
The Forge doesn't change anything if you use the spring that comes with it. Don't need a tune for that. The K+N reportedly causes no change in trims and doesn't "need" to be tuned for. I haven't tested it myself, can only report what I've seen posted here.
Old May 24, 2012 | 09:09 PM
FasterIsBetter's Avatar
Its the spanish form of "Panda" LOL!!!
Old May 25, 2012 | 08:15 AM
CudaJoe's Avatar
yea, K&N intake seems to work without a tune on 90% of vehicles on here. I know it works perfectly for me and Im right near sea level.
Any type of scan guage or scan tool that reads fuel trims off the OBDII is your friend . It will help you narrow down the the right placement of the filter.
Old May 25, 2012 | 02:49 PM
So the K&N , is it a short ram I want or a cold air ? And , Which site has them ?
Old May 25, 2012 | 02:53 PM
BPacak's Avatar
Vtec Rep
no you dont need a tune but its always a good idea to get one, i ran the same setup without a tune for a couple months and it was fine.
Air Intake - K&N Typhoon Intake 08-10 Cobalt SS Turbo
Old May 25, 2012 | 03:36 PM
DPveritasGold's Avatar
Here's all the information you need to know about the K&N SRI..... buy it. The main advantage is that it makes your turbo sound loud and awesome. I've been running it with GMS1 for months now with no issues.
I also have the forge bpv. Honestly, I didn't think it was any louder than stock. In fact, I felt that it was a bit more quiet. However, I do feel that now it produces a more quality blow off sound because it's metal and not rubber. Also, it's much more durable than the stock one. I have no complaints and would recommend it. BUT, I would not recommend it without getting the K&N SRI first.
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
Trav3480
Oct 1, 2015 08:17 PM
Trav3480
Sep 28, 2015 02:46 PM
