Forge Intall
Old May 20, 2011 | 03:10 PM
StreetDrag03's Avatar
Forge Intall
Forge Install* lol. So I searched and came up with nothing. I simply just want to know which direction to install the forge bpv into my car. I haven't taken my old one out yet so maybe that will answer my question, but I don't want to take the old one out really unless I already know lol. Thanks.
Old May 20, 2011 | 03:21 PM
BPacak's Avatar
Vtec Rep
with the opening facing down.
Thank you.
Old May 20, 2011 | 04:21 PM
BooSSted's Avatar
It'll very obvious once you take your stock one out. Make sure you leave the vacuum line attached to the stock one while you're taking it out. It holds the spring and the diaphragm in place
Old May 20, 2011 | 04:29 PM
vahdyx's Avatar
Oh no way, I totally installed mine facing up
Imma Idiot!!! been driving around with it for months now in the wrong direction. Might as well grease it up too
*Well I'm off to change it now, Absolutely hate taking off the intake and dealing with it, but must be done*
Old May 21, 2011 | 10:27 AM
MajorCB's Avatar
Obviously this was a good post! hahaha cause mine is in the mail and on the way to the house... I couldnt wait for a group by unfortunately...and by the sound of it, the intake is gonna be a pain... great!!
Old May 21, 2011 | 11:03 AM
SSlobalt's Avatar
Dude. You gotta let us know if there is any difference in the way it runs.
Old May 21, 2011 | 11:48 AM
vahdyx's Avatar
I'm not sure now.... I stripped my turbo installing my Bypass valve.... I'm a bit tore up about it.
Old May 21, 2011 | 12:11 PM
BPacak's Avatar
Vtec Rep
hahaha how did you manage that?
Old May 21, 2011 | 01:47 PM
BooSSted's Avatar
**** happens. Get a thread tap and fix it!
Old May 21, 2011 | 01:49 PM
MajorCB's Avatar
wait did you just do that when you went down to change its position?? .. and how does one strip the turbo? ... did you run a tool up against it or something?
Old May 21, 2011 | 01:59 PM
FRQ FLYR's Avatar
It's aluminum- be careful not to cross thread/overtighten.
Old May 21, 2011 | 02:05 PM
MajorCB's Avatar
ahh.. ok.. are there any manuals that suggest a proper torque setting to the set screws? or is it just tighten to "snug"
Old May 21, 2011 | 02:56 PM
vahdyx's Avatar
Well good news,
My valve upside down didn't make much noise so I thought it was just there to get rid of the plastic and rubber pieces of the stock. Now that it's right side up it sounds much much better.
I must have over tightened it and when I untightened it it must have stripped. That's my guess.
Old May 21, 2011 | 04:05 PM
SSlobalt's Avatar
Does the forge unit come with mounting bolts? That thing has a much thicker base than the stock BPV plate.
Old May 21, 2011 | 04:07 PM
BPacak's Avatar
Vtec Rep
use the stock bolts
Old May 21, 2011 | 04:14 PM
vahdyx's Avatar
Mine didn't, but all is well. I fixed my bolt problem. I just bought a slightly longer bolt. Only the first part of the whole was stripped. Luckily the bolt is smaller than the hole (lol) and there was plenty of extra threading to use.
Old May 22, 2011 | 03:05 PM
MajorCB's Avatar
Well good news,
I dont suppose you took pictures of it in the wrong and right positions did ya? so when I get mine, I'll know what's what?
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
