FTW-k04R vs ZFR In need of turbo swap!!
Old Mar 28, 2015 | 05:44 PM
  #1326
KMO43's Avatar
Originally Posted by Terminator2
At your altitude anything under 5 seconds is quite good anything under 4.5 would be great (assuming a bone stock K04 on E-47 or meth)
I did a 4.812 still need to dial it in too wish I had e!!!
Old Mar 29, 2015 | 03:16 PM
  #1327
Terminator2's Avatar
At sea level on stock K04 and E-47 no cams just bolt ons 4.0 is possible. You are at ~3000 ft right?
Old Mar 29, 2015 | 04:10 PM
  #1328
KMO43's Avatar
3557ft
Old Mar 29, 2015 | 07:23 PM
  #1329
T-Man's Avatar
Thanks for the updates. Hoping to be able to get ahold of Matt on Monday. Was told he had cores coming in a few weeks ago...
Old Mar 29, 2015 | 07:46 PM
  #1330
KMO43's Avatar
No prob I wish I had more time I'm a busy guy working 2 jobs but I try to keep the info coming
Old Mar 30, 2015 | 11:49 AM
  #1331
CudaJoe's Avatar
The K04FTW is a big wheel turbo built by Turbo Bay Performance based in Florida. Don't quote me 100% but it has a 65mm billet wheel and is only $495.
Basically a tiny bigger than the K04+ but less than half the price
These are pics of mine
65mm billet wheel would be the Exducer measurement? What is the Inducer measurement? Factory K04 is 56mm exducer and a 43mm inducer. For comparison, BNR GT2871 is well... 71mm Exducer and 53mm Inducer.
Either way for less than $500, that's a hefty increase in compressor size, should see definite measureable gains. The turbine side isn't touched?
Old Mar 30, 2015 | 07:34 PM
  #1332
nathan112i's Avatar
50mm x 65.9mm
Old Mar 31, 2015 | 10:02 AM
  #1333
CudaJoe's Avatar
thank you. If that was in one of the other 54 pages, im sorry
Okay Im on the band wagon, this sounds like a fantastic option for the price. What do you do, mail them a K04 with a check for $495?
Old Mar 31, 2015 | 10:06 AM
  #1334
KMO43's Avatar
I'd buy it with the $95 actuator too!!
Old Mar 31, 2015 | 10:12 AM
  #1335
breds2k's Avatar
I gave after getting half way through thread with no answers. Can I get some cliff notes?
1- Who has been running this and for how long? Reliable? Heard about premature seal failure from a local guy (cant confirm that)
2- We gains confirmed other than a dyno that showed 18+hp? But carried 50whp more to redline?
Old Mar 31, 2015 | 12:28 PM
  #1336
KMO43's Avatar
I've been running mine really hard for over a year without a single issue.
No dyno but I can hold 26psi+ at 6500
Old Mar 31, 2015 | 03:42 PM
  #1337
CudaJoe's Avatar
Theres going to be a HP gain. GT2871 from BNR supercars will get you roughly 50 hp gain. The ZZP ZFR direct swap on pump gas is also probably a 50 hp gain. Id say this wheel has to be good for 20-30 hp on pump gas and for that price that is pretty good cost to power ratio.
Now with supporting fueling mods and running e85 it will be more. I think that's what KM043 is trying to do but hasn't dyno'd yet. You have cams with the fuel pump lobe upgrade? and running E47 KM043?
Old Mar 31, 2015 | 03:46 PM
  #1338
dearbryant's Avatar
He is not on ethanol, and i believe stock cams but with meth.
I have the k04r and should be going e85 in the next two weeks with upgraded intake cam with the bigger fuel pump lobe.
Old Mar 31, 2015 | 03:52 PM
  #1339
KMO43's Avatar
I'm in canada no E here American doesn't share 😟 I'm running meth with the actuator it holds really well but also I wasn't planning on dynoing.
If somebody runs E fully bolted with the actuator that'll be a good setup
Old Mar 31, 2015 | 04:16 PM
  #1340
Devin86's Avatar
It's gonna have more psi at redline. Some ppl are getting caught up in pure HP numbers. The real deal is the power band just went up 1k+. The k04 is good just doesn't have the ***** in the higher rpm rang. This k04r is the answer to ppl not wanting a 500hp cobalt but a little more pull up top.
Old Mar 31, 2015 | 05:06 PM
  #1341
CudaJoe's Avatar
basically from what Ive seen
LNF K04 factory________has a 43mm Inducer_____56mm Exducer________price varies..________32-34? Ib/min
Werksracing WR-1 K04+__has a 46.5mm Inducer___60mm Exducer________$1250, direct bolt on_____38.4 Ib/min
BNR GT2860 ___________ has a 47.3mm Inducer___60mm Exducer_______$950, direct bolt on______38 Ib/min
K04R__________________has a 50mm Inducer____65.9mm Exducer ______$495, direct bolt on______???
Hahn super20G kit_______has a 52.6mm Inducer___68mm Exducer________$1199, need BOV_____43 Ib/min
BNR GT2871___________has a 53.2mm Inducer____71mm Exducer________$1200, need BOV_____???Ib/min
ZZP ZFR 6758__________has a 54mm Inducer______67mm Exducer_______$1940, direct bolt on____49Ib/min
ZZP S256 kit___________has a 56mm Inducer______80mm Exducer_______$3100, need BOV______58 Ib/min
ZZP ZFR 7163__________has a 57mm Inducer______71mm Exducer_______$2240, direct bolt on____60 Ib/min
ZZP S259 kit___________has a 59mm Inducer______80mm Exducer_______$3300, need BOV______62 Ib/min
Those are the turbo options that I know of.
Old Mar 31, 2015 | 05:11 PM
  #1342
T-Man's Avatar
I'll have ethanol dyno numbers with the upgraded actuator soon... Just need the turbos
Old Mar 31, 2015 | 06:11 PM
  #1343
KMO43's Avatar
That's what I'm curious about
Old Mar 31, 2015 | 06:26 PM
  #1344
nathan112i's Avatar
i have seen 37lbs a min in datalog and i am sure there is more, WG actuator would help alot too
Old Mar 31, 2015 | 06:35 PM
  #1345
KMO43's Avatar
I've hit more than 37lbs/min
Old Mar 31, 2015 | 08:04 PM
  #1346
CudaJoe's Avatar
If its 41 or 42 Ib/min, sounds awesome lol.
Old Mar 31, 2015 | 09:17 PM
  #1347
63 Nova SS's Avatar
basically from what Ive seen LNF K04 factory________has a 43mm Inducer_____56mm Exducer________price varies..________32-34? Ib/min Werksracing WR-1 K04+__has a 46.5mm Inducer___60mm Exducer________$1250, direct bolt on________??? BNR GT2860 ___________ has a 47.3mm Inducer___60mm Exducer_______$950, direct bolt on______38 Ib/min K04R__________________has a 50mm Inducer____65.9mm Exducer ______$495, direct bolt on______??? Hahn super20G kit_______has a 52.6mm Inducer___68mm Exducer________$1199, need BOV_____43 Ib/min BNR GT2871___________has a 53.2mm Inducer____71mm Exducer________$1200, need BOV_____???Ib/min ZZP ZFR 6758__________has a 54mm Inducer______67mm Exducer_______$1940, direct bolt on____49Ib/min ZZP S256 kit___________has a 56mm Inducer______80mm Exducer_______$3100, need BOV______58 Ib/min ZZP ZFR 7163__________has a 57mm Inducer______71mm Exducer_______$2240, direct bolt on____60 Ib/min ZZP S259 kit___________has a 59mm Inducer______80mm Exducer_______$3300, need BOV______62 Ib/min Those are the turbo options that I know of.
You can update the +---
I've seen 38.4 on the+ at 6300. I'm not carrying 25-26 at 6500 like he is getting on the r. May have to try that different actuator.
Old Mar 31, 2015 | 10:02 PM
  #1348
KMO43's Avatar
Ya it'll work well for you too. As always I'm at altitude and have no access to E so I'm SOL
Old Mar 31, 2015 | 11:01 PM
  #1349
CudaJoe's Avatar
That would be the k04+ or the K04r that your seeing 38.4 on?
Old Mar 31, 2015 | 11:02 PM
  #1350
Devin86's Avatar
"on the +". think he would have said "on the r" if he was taking about the k04r haha
