Fuel trims
Fuel trims
So what should I want my lfts to be. Think I got that right. I was at 7.8 with k&n then I retuned to the new trifecta tune that take maf out of the equation , now I'm at -6.4
Ya with my Hahn cai I was at worst 3, now with k&n it's off it's rocker. Tried changing filter position, don't work. Still the same
Ya will log it then I guess
I got it retuned for k&n . Or did I forget to tell him that I had one. He did look at it and said it was good. I'll try again and mention the trims
My trims used to be around +7-8 for some reason. Did an oil change, changed plugs, and seafomed the car and now they are consistent around 1.5. I guess basic maintenance helps is what im getting at.
I've had some negative fuel trims every since I blew my hotside tube off my IC I'm around -2.3 STFT and -0.9 LTFT at cruise. I'm convinced I have a small leak. I just need to stop being lazy and fix it.
