Fuel trims
Old Sep 5, 2012 | 02:29 PM
tomj77's Avatar
Fuel trims
So what should I want my lfts to be. Think I got that right. I was at 7.8 with k&n then I retuned to the new trifecta tune that take maf out of the equation , now I'm at -6.4
Old Sep 5, 2012 | 02:31 PM
Frogstofall's Avatar
That's still off. I think most tuners like them to be +/- 1 or as close to 0 as possible.
Old Sep 5, 2012 | 02:39 PM
TommyP's Avatar
AWD > FWD
after tuning my LTFTs were right around +/- .7 at all times. You want it as close to zero as possible.
Old Sep 5, 2012 | 03:15 PM
slapbetcommissioner's Avatar
Just GMS1 with a K&N SRI im usually about +/-3 usually and at worst 5-8 and thats only for a couple seconds
Old Sep 5, 2012 | 03:40 PM
ItalianJoe1's Avatar
A couple percent while driving isn't a big deal. Log it again and send it back to vince so he can adjust it more, but it's not gonna hurt anything.
Old Sep 5, 2012 | 03:42 PM
tomj77's Avatar
Ya with my Hahn cai I was at worst 3, now with k&n it's off it's rocker. Tried changing filter position, don't work. Still the same
Ya will log it then I guess
Old Sep 5, 2012 | 03:57 PM
Map sensor could be dirty.
Also was your tune done specifically for the HAHN and now you have a k&N? Or did you get re tuned for the K&N?
Old Sep 5, 2012 | 04:00 PM
tomj77's Avatar
I got it retuned for k&n . Or did I forget to tell him that I had one. He did look at it and said it was good. I'll try again and mention the trims
Old Sep 5, 2012 | 04:02 PM
tomj77's Avatar
I also just switched from 91 octane to 94 with 10% E
Old Sep 5, 2012 | 04:10 PM
^^Way to leave that tidbit of info out of your original post. That could very easily skew trims a bit.
Old Sep 5, 2012 | 04:15 PM
09CobaltSS1's Avatar
Any unaccounted for ethanol in the system will cause the trims to swing more to the possative to enrichen the mixture, not negative though..
Old Sep 5, 2012 | 04:57 PM
tomj77's Avatar
It was positive, till I did the tune that disables maf sensor . I'll put that tune back and retune
Old Sep 5, 2012 | 05:12 PM
Dart_SI's Avatar
My trims used to be around +7-8 for some reason. Did an oil change, changed plugs, and seafomed the car and now they are consistent around 1.5. I guess basic maintenance helps is what im getting at.
Old Sep 5, 2012 | 05:24 PM
SSlobalt's Avatar
I've had some negative fuel trims every since I blew my hotside tube off my IC I'm around -2.3 STFT and -0.9 LTFT at cruise. I'm convinced I have a small leak. I just need to stop being lazy and fix it.
Old Sep 5, 2012 | 05:33 PM
tomj77's Avatar
i just did all that.
turbochargedss2012
Sep 20, 2023 12:17 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
