Gen 3 Oil Cooler Location
Old Mar 7, 2014 | 11:29 PM
taintedred07's Avatar
I have a gen 3 2.1l and we're trying to find a place to put the oem lnf oil cooler. The location on the gen 3 block doesn't have the same passages as the lnf block in the same location.
Old Mar 8, 2014 | 02:18 AM
JapEatr's Avatar
South Central *********
Old Mar 8, 2014 | 08:58 AM
Spawne32's Avatar
gen3's dont have oil cooler's I thought.
Old Mar 8, 2014 | 09:14 AM
InfraRedline's Avatar
I don't have an oil cooler on my Gen 3 2.4 block.
Old Mar 8, 2014 | 10:24 AM
So you don't run one at all?
Old Mar 8, 2014 | 10:31 AM
No sir. Still takes 7 quarts of oil too
Old Mar 8, 2014 | 06:17 PM
Omiotek's Avatar
certain gen 3 blocks have oil coolers and some dont.......... the last ldk i did had one.
your sol dude..... this is why you ALWAYS need to check stuff like that. the amount of work it is to make that work isnt fun nor easy if you want it done correctly. look at your lnf block and thats what you have to replicate.
Old Mar 8, 2014 | 06:50 PM
Nah, if I have to we'll route an aftermarket cooler like mongo's setup.
Old Mar 8, 2014 | 06:52 PM
Spawne32's Avatar
Unless your track racing or autox you dont have to worry about an oil cooler, thats why GM did away with them on most of the blocks.
Old Mar 9, 2014 | 09:03 AM
C_A_D88's Avatar
Subd just bought a gen3 2.4
Old Mar 9, 2014 | 09:17 AM
Bluelightning's Avatar
Got Bewst?
When I bought my Gen 3 motor from zzp it came with a new oil cooler. Contact them for a new one.
Old Mar 10, 2014 | 06:57 PM
Talked to zzp and added a modified stock oil cooler for the gen 3 for $50 to my order.
Old Mar 11, 2014 | 11:12 AM
Hockeyman's Avatar
not bad at all
Old Mar 19, 2014 | 10:21 PM
The oil cooler from zzp does not fit on the block, I thought they modified the oil galleys or whatever it's called so it could mount on the gen 3 block as if it was stock. They just modified the angle on one of the hose fittings.
So I'm probably going to buy an aftermarket oil cooler, anyone have any experience with these or suggestions?
Old Mar 20, 2014 | 12:53 PM
Been talking to Jeff and what his setup consists of.*
Apparently there's alot of differences between the ldk and 2.4 gen 3, that's why the zzp cooler won't work. Mongo was saying he's gonna use a Ford oil cooler forget what vehicle but its compact, and I guess there's a oil galley behind on the oil filter just on the 2.4 gen 3 that I can use for the oil cooler, then route the other end of the cooler to the turbo feed.
Old Mar 20, 2014 | 12:55 PM
so THAT's what that is... i didn't know if it was an oil cooler, coolant cooler, coolant warmer, etc lol
Old Mar 20, 2014 | 11:58 PM
Got Bewst?
Aweeee diiiirty. Sorry man I didn't know it would be different between blocks. ZZP should have known that. They didn't even mod the hose fitting on mine. It faces the opposite way.
Old Apr 30, 2014 | 07:11 AM
mongorat427's Avatar
Theres a main oil galley plug right under the oil filter and this galley also goes to the head where there is another plug . If your turbo you can run the line to a trans or power steering cooler and then right to the turbo. No 4AN line is perfect size
I used a Ford power steering cooler. You can run bigger fittings if your using it as a cooler only or put a T in it for the turbo. no 6 or 8 would work in that case.
Old Sep 17, 2015 | 03:20 AM
Just an fyi to any 2.4 gen 3 owners, do not use the oil galley plug, on the filter housing, for your turbo feed line. I killed 2 turbos from oil starvation because there was no pressure coming from that plug.
Old May 6, 2018 | 12:37 AM
Henry3959's Avatar
I know this is an old post... Has anyone else experienced this? Is it true there is no oil pressure at that oil plug?
Old May 6, 2018 | 10:08 AM
Pull the plug and crank the engine, youll find out.
Old May 6, 2018 | 02:20 PM
Henry3959's Avatar
That could be messy
biniecki
Oct 25, 2015 02:23 PM
Trav3480
Oct 1, 2015 08:17 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
