GM Performance Cat Back
Old Jul 29, 2008 | 04:14 PM
TrevMo's Avatar
I was taking a look at the GM Performance Cat Back comparing it to the Hahn and noticed that it looks like the GM exhaust comes with a new catalytic converter. Is this a high flow cat? Would it offer significant improvement in flow compared to the stock cat?
I'm wanting to keep the cat converter to stay legal, but was wondering if the cat that is on the GM exhaust would result in a better setup than a Hahn with the stock cat.
Any thoughts on the stock cat and the GM performance cat would be appreciated!
Old Jul 29, 2008 | 04:15 PM
SSpdDmon's Avatar
I'd guess that it's not a cat, but a resonator.
Old Jul 29, 2008 | 04:17 PM
TrevMo's Avatar
Alright...well after showing my lack of exhaust knowledge...would there be any advantage to go with the GM exhaust instead of the Hahn bolted up to the stock cat?
Old Jul 29, 2008 | 04:20 PM
krispy's Avatar
GM exhaust is 2.5" diameter, hahn is 3" diameter
TurboSS's Avatar
ya you get to keep your 5 year 100,000 mile warranty
Old Jul 29, 2008 | 04:21 PM
Tomtwtwtw's Avatar
Aside from potential warranty issues, I can't see any advantage. GM exhaust is either 2.25 or 2.5 inches, can't remember for sure, but not as free-flowing as the Hahn unit. I'd love to hear some sound clips on both the tc, though...the track videos of HRC are too hard to hear. They need to get some fly-bys up on the site like they do with their ss/sc cat-back.
Old Jul 29, 2008 | 04:38 PM
krispy's Avatar
getting a new catback isn't going to void the rest of the powertrain warranty
Old Jul 29, 2008 | 04:41 PM
TurboSS's Avatar
Really? Call GM or better yet call your dealer. Wow I wish my dealer was as cool as yours
Old Jul 29, 2008 | 04:43 PM
steddy2112's Avatar
Try 2.25
Way too small for an LNF Balt
Old Jul 29, 2008 | 04:50 PM
TrevMo's Avatar
Since I obviously am not familiar with the parts of the exhaust...
What are the physical differences?
I understand the issues with size...but what about the resonator that is on the GM one...any other physical differences besides the tubing diameter?
Old Jul 29, 2008 | 04:52 PM
krispy's Avatar
Originally Posted by steddy2112
Try 2.25
really? stock LNF exhaust is 2.5 so GMPP would be a downgrade
sucks for people that don't realize that
Old Jul 29, 2008 | 04:55 PM
steddy2112's Avatar
Also the downpipe is already three inches and catted...so the only upgrade would be catless...
Old Jul 29, 2008 | 04:57 PM
SynapseTurbo's Avatar
the stock exhaust system is a mandrel bent 2.5" system.
Old Jul 29, 2008 | 04:58 PM
TrevMo's Avatar
So basically, the only upgrade while keeping the cat would be to go for the Hahn 3" in order to increase the diameter? Any use of the GM exhaust would be pointless based on the exhaust that they put on the SS/TC?
Old Jul 29, 2008 | 04:59 PM
steddy2112's Avatar
Yep.
And a catless pipe will still be kinda quiet.
Turbo muffles quite a bit of noise.
Old Jul 29, 2008 | 05:24 PM
TrevMo's Avatar
If you are not messing with the cat (removing it to replace with a downpipe) or header, an aftermarket exhaust should not void any warranties...
If you mess with anything that will throw a code, you are running a risk of voiding your warranty...just bolting on a larger exhaust will not void anything....
Old Jul 29, 2008 | 06:35 PM
08blackbaltss's Avatar
2.5" is good for around 400hp why not spend the money on something better like TUNING and then worry about the exhaust when you need to change it out... if there is even a need. I wont be changing mine untill it proves to be restrictive and without a good bit of work I dont see that happening. Get a tune or maybe intake when it comes out.
Old Jul 29, 2008 | 06:55 PM
although its possible to make 400whp on a 2.5" exhaust thats a lot of restriction you have to overcome. there are definate gains to be had in the 300-400whp area with a 3" exhaust. at the 300whp level on other cars we have tested showed gains of 15-20whp without any other changes.
Old Jul 29, 2008 | 07:01 PM
oh absolutely, I will not argue that point at all. but I do think it would be better to get there first and then worry about it later... Maybe until a company by the name of Synapse comes out with a cat back?
Old Aug 11, 2008 | 08:48 PM
sparhawk's Avatar
i was just reading on that GM performance exaust and it is NOT compatible with the 2.0LNF, so we will have to wait.
Old Aug 11, 2008 | 09:12 PM
FiscalFizz's Avatar
you don't know this 100%.....call YOUR dealer. And I believe you can have your vehicle serviced at any dealership (GM).... duh.....so just check around... dunnno when it comes to warranty work..
Old Aug 11, 2008 | 10:19 PM
rukkee's Avatar
They can't void your warranty because of a catback no matter what dealer . Before the cat they can give you crap , but catback isn't going to affect anything .
GMPP is too small for a LNF and besides doesn't the LNF downpipe have a 3 bolt flange? GMPP CB has only a 2 bolt.
Old Aug 12, 2008 | 01:34 AM
1WhiteSSTC's Avatar
Confirmed, GMPP does NOT have an exhaust out for the cobalt ss/tc, YET..........
turbochargedss2012
Sep 20, 2023 12:17 PM
Tupp
Sep 30, 2015 08:18 PM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
