GMS1 Sensor Install Question
Old Aug 9, 2011 | 09:02 AM
chevyguylt1's Avatar
So im going to install the GMS1 Sensors. But i have a question for everyone.
I already am HP Tuned, and wonder if i can just install the 2 sensors and will be good to go or will i need to be retuned? (ALSO WILL THE CAR BE OKAY TO DRIVE FOR A WEEK IF I DO NEED TO BE RETUNED?)
I dont want to install the 2 sensors if the car cant be driven if i DO need a retune.
I only purchased the 2 sensors, not the entire GMS1 upgrade because i run my own tune.
Thx!
Old Aug 9, 2011 | 09:10 AM
MastaShaKe_88's Avatar
I dont have an answer for you... but I was lookin at buyin those sensors 2, How hard is the install if you do it yourself?
Old Aug 9, 2011 | 09:19 AM
AcesNEights's Avatar
Its not hard to install, just have to cut and solder the wires together and make it look neat lol
But you do need a retune once you put them in before you drive ur car.
Old Aug 9, 2011 | 09:24 AM
BlackSS185's Avatar
you'll need a re tune the car will start up but once you drive/ hit boost if will go into limp mode i believe... also make sure u got the correct oring for the sensors the one that come with the sensors are wrong(unless you bought the kit from CED or the dealer) and also make sure u cut the nipple off the sensor so it will sit flat on the lower charge pipe, if you have the instruction you'll see what im talking about
Old Aug 9, 2011 | 10:36 AM
Iam Broke's Avatar
You can drive it easy for a while but don't get into the boost. I'd retune it on sensor install though. You can keep the stock base file and just change the sensor data in HPTuners. Boosts better without the GMS1 file.
Old Aug 9, 2011 | 04:05 PM
D-mac's Avatar
Did you just buy the sensors or did you also get the pigtails?
They aren't plug and play
You will need the Stage 1 flashed on your car via HPT
Old Aug 9, 2011 | 04:42 PM
umrdyldo's Avatar
Did no one ever make plug and play pigtails. Someone could have make some cash doing that.
Old Aug 9, 2011 | 06:25 PM
Iam Broke's Avatar
No adapter plugs that I know of, it would be nice though. Maybe BYT's shop or ZZP can do it.
Old Aug 9, 2011 | 09:42 PM
D-mac's Avatar
Its really not a hard install
I put deutz connectors on my stock and also my stage 1 sensors so i can switch back and forth between them
Old Aug 9, 2011 | 09:43 PM
Iam Broke's Avatar
Smart man!
brandon04
Oct 21, 2015 07:04 AM
justinchinn
Oct 2, 2015 12:18 PM
maliki778
Oct 1, 2015 07:39 PM
Bohb
Sep 27, 2015 09:11 PM
jmelton327
Sep 26, 2015 10:04 PM
