gms1 sensors
Don't bother unless you can flash it with GM tune.
The stock sensor on the intake manifold is a 3-wire MAP sensor. The stock sensor on the coldside pipe is a 4-wire TMAP sensor. The "T" is for "temperature" feedback. The GMS1 sensors are both 4-wire TMAP sensors, but the temperature feedback wire isn't used on the sensor in the intake manifold position.
your iat1 signal is coming from your MAF sensor located in the fresh air inlet stream prior to the turbo (unless you have done a maf relocation of course), and your iat2 signal comes from your tmap sensor located in your cold side charge piping between your intercooler and throttle body. The second map sensor is located in/on your intake manifold which is solely a manifold pressure sensor
Sl0wbaltSS
Nov 21, 2018 11:11 PM
