Grinding Noise From Left Side
Old Jan 16, 2013 | 11:52 AM
TurboMatt's Avatar
Im getting a grinding noise from the drivers side when driving but when I step on the clutch it goes away. Anyone have any ideawhat this could be. I always have a clicking while not moving that also stops when the clutch is pressed down but Im pretty sure that's the throwout bearing.so I was wondering if both issues could be due to the throwout bearing or something else.
Old Jan 17, 2013 | 09:55 AM
FasterIsBetter's Avatar
Has your clutch ever been replaced? You could be low on trans oil from the install loss. Also could be the clutch or throwout bearing.
Old Jan 17, 2013 | 10:11 AM
prevsrt4owner's Avatar
Sounds like a bad TOB. Just guessing.
Old Jan 17, 2013 | 10:14 AM
lazaro's Avatar
I have the same issue
Old Jan 17, 2013 | 07:03 PM
TurboMatt's Avatar
I had the clutch replaced about a year ago with a KY Stage 3 and a month after replaced the throwout bearing because it went completely bad and my clutch pedal was stuck to the floor. It was fine for months after that and now Im getting the grinding noise and clicking. It doesnt seem to drive any different its just the noises right now.
Old Jan 17, 2013 | 07:16 PM
nikemax21's Avatar
Sounds like a combination of the output shaft bearing and throwout bearing. I had the same noise while driving then when u pressed in the clutch the noise would stop. Gm replaced the trasmission under warranty. The noise while idling with the clutch out and not in gear could be the slave cylinder
Old Jan 18, 2013 | 11:53 AM
SSlobalt's Avatar
this
biniecki
Oct 25, 2015 02:23 PM
dennis69
Oct 20, 2015 04:49 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
