Injen Charge pipe
Old Jan 15, 2013 | 08:56 AM
user 72239's Avatar
Injen Charge pipe
So i have injen upper charge pipe, and i've popped it off twice now when I hit full boost. it has shitty C clamps and I am thinking about buying tclamps, anyone know what size i should get? I've never had to buy them before.
Old Jan 15, 2013 | 10:14 AM
northvibe's Avatar
ah sheet I had all the parts list posted somewhere. I think it is 2.5" turbo and ic side and 3 inch to connect the injen pipes. You'll want longer couplers too. the stock injen are short as f.
EDIT: don't listen to my 3" ones check thread below.
Old Jan 15, 2013 | 10:16 AM
northvibe's Avatar
Ah check this Found it. Search :-p
https://www.cobaltss.net/forums/2-0l...clamps-202651/
Old Jan 15, 2013 | 10:26 AM
user 72239's Avatar
sweet. thanks. I will order those. tired of it blowing off
Old Jan 15, 2013 | 10:29 AM
northvibe's Avatar
f I know! I installed my injen, went to get on the hwy..POOF. had to limp that **** home and be the dbag going way too slow.
T clamps and the couplers are amazing. Don't over tighten, you'll crush the injen. Just enough to see the tclamp push into silicone.
Old Jan 15, 2013 | 10:40 AM
user 72239's Avatar
so from your post I should order
1x Silicone Turbo Hoses
2x T Bolt Clamp
Old Jan 15, 2013 | 11:20 AM
Cobe's Avatar
Originally Posted by northvibe
Your guys cars didnt have the t bold clamps stock on the stock charge pipe?
Old Jan 15, 2013 | 11:41 AM
user 72239's Avatar
I bought the car used with the injen on it. so I never had a chance to use them
Old Jan 15, 2013 | 12:07 PM
09BlkCrusader's Avatar
Or just get this:
Intercoolers & Pressure Piping - MPx Coupler Upgrade Kit (For Use w/ Injen Upper Pressure Piping) 08-10 Cobalt SS
I personally wouldn't buy it, especially for that price tag, there are cheaper alternatives, but there are plenty of options, and these dimensions will give you the basic understanding of what you'll need.
Old Jan 15, 2013 | 12:09 PM
user 72239's Avatar
haha, I have never seen that before. interesting
I only really need the turbo connection since the others have been holding fine.
Old Jan 15, 2013 | 12:57 PM
northvibe's Avatar
I did not want to cut and hack my stock pipes.
Old Jan 15, 2013 | 01:00 PM
northvibe's Avatar
order from siliconintakes cheap and fast.
http://www.siliconeintakes.com/
Ok my bad you'll need:
3" long couplers
1 x 2.0"
2 x 2.5"
Tbolts
2 x 2.0" tbolts
4 x 2.5" tbolts
Old Jan 15, 2013 | 01:03 PM
northvibe's Avatar
2" tbolt
T Bolt Clamp
2.5" tbolt
Hose Clamp
3" long 2 inch diameter coupler
3" long 2.5 inch diameter coupler
Old Jan 15, 2013 | 01:05 PM
northvibe's Avatar
**** we should sticky a injen install with the parts...Can't believe I had the wrong parts. I've posted it in like 12 threads .
here is where I had the right list
https://www.cobaltss.net/forums/2-0l...pe-ect-243838/
Old Jan 15, 2013 | 01:46 PM
Cobe's Avatar
no im saying my car came stock with t bolt clamps on the charge pipes.. lower and upper just like the brand new ones I purchased from zzp. There is honestly no difference in the stock T bolt clamps on my charge pipes than the ones I just bought..
sorry this picture is not about the charge pipe.. more about the end tank of the intercooler but you can tell that i have the same t bolt clamps as the ones I purchased from zzp...
Old Jan 15, 2013 | 04:07 PM
northvibe's Avatar
yeah stock does have tbolts, BUT they are built into the rubber stock hose ends. you have to cut them out if you want to reuse them.
Old Jan 15, 2013 | 07:32 PM
Frogstofall's Avatar
All you have to do is cut one little flap open and they slide right out. Its not like you're gonna hack up the stock pipe/coupler to get them.
I actually bought the MPx upgrade kit. It was pricey but it the pipe never once blew off on stock turbo or the BNR.
Old Jan 15, 2013 | 11:23 PM
LE5_AJ's Avatar
Ah... good old silicone intakes I've gotten a lot of stuff from them since then. I'm very pleased with the quality and service and i get it next day since i'm so close.
To OP the T-bolt clamps should be good and if that isn't enough hair spray... seriously. Though you shouldn't be having that big of an issue.
Old Jan 16, 2013 | 10:14 AM
ampzor350's Avatar
Damn y'all girls need to learn how to tighten some bolts! I have the injen piping and I think the couplers are perfectly sized and haven't had a problem on a 23psi tune. Lol
Old Jan 16, 2013 | 10:23 AM
You must drive like an old lady then bc those couplers suck.
Old Jan 16, 2013 | 11:17 AM
user 72239's Avatar
happened twice since ive been tuned. Ill hit 24 psi and boom goes the pipe lol
Old Jan 16, 2013 | 11:18 AM
northvibe's Avatar
Yup not cutting ****.....
Old Jan 16, 2013 | 11:28 AM
yamaha288's Avatar
I used the stuff that came with the injen have hit 30lbs on the ZFR never blown one off I think its instalation error if they blow off.
Old Jan 16, 2013 | 12:01 PM
Nfamous60's Avatar
just brought some new ones. tanx
Old Jan 16, 2013 | 12:33 PM
northvibe's Avatar
how do we know?!? How can we trust you?! injen CP isn't in your sig!!! Conspiracy!!
