ground kit?
Old Aug 27, 2009 | 04:27 PM
Ryan88924's Avatar
Cobaltls 14, lets see some pictures
Old Aug 27, 2009 | 05:50 PM
CobaltLs_14's Avatar
when i get home i will take pics
Old Aug 27, 2009 | 06:01 PM
northvibe's Avatar
Originally Posted by buellfooll
Don't you guys get it? When you start your car you're drawing 200 plus amps from your battery. That means you have that 200 amps available to run everything on the car PLUS the batteries reserve capacity. It only takes 25 or 30 amps to run everything in your car at the same time, except the starter. Cable size determines current carrying capacity. You can hook a 18 gauge wire to your system or a 00 gauge the voltage will be the same, but the 18 gauge wire will melt with anything more than a couple of amps applied to it and the oo will laugh at you. Google "ohm's law' and learn something about electricity before you waste your hard earned money. Really!
I
f you're ADAMANT you need bigger cables/wires just run a cable/ wire slightly smaller that what is already there, in parallel to the existing. Electrically it accompishes everything you think bigger cables will.
Unless, of course, you're after more bling than zing.
I'm done!
this isnt for a system...this is to make ground points on the car closer to "perfect" ground.
Oct 20, 2015 09:56 PM
dennis69
Oct 20, 2015 04:49 PM
Sep 28, 2015 12:51 PM
metroplex
Sep 27, 2015 07:48 AM
