Hahn charpes with Treadstone or ZZP intercooler?
I got my hands on some hahn charge pipes (lower and upper charge pipes with couplers). Now I'm in the market for a intercooler. Will these charge pipes fit both, one of them, or neither?
If you have one of these setups, what was the difficulty level of the installation? Any helpful tips are appreciated.
I hear that the treadstone one takes a bit more effort to make fit than the ZZP does. As for installation, I mean if you are semi competent and have the right tools, it's fairly straight forward. You've gotta take your bumper off though.
yea, I believe it should be fairly easy, but I'm NOT looking forward to installing the lower CP. I read on another thread that there's some 90 degree piping needed to install the TR models or does this comes with all aftermarket intercoolers for the LNF?
i have the hahn charge pipes with the Treadstone TR8 intercooler. everything went together fine. the lower pipe can be a pain in the ass but as long as you instal everything at the same time as the intercooler it should be a lot easier as it will give you some more movement to work with. i would remove old intercooler instal piping and then put on new intercooler. to me that would be the easiest way.
I have the Hahn CP and ZZP IC. Everything fits, but like you said the lower CP is a bitch to put on. Having the intercooler off should help a lot. Good luck with the install!
