Head work.
Old Feb 16, 2009 | 05:28 PM
HunterKiller89's Avatar
Head work.
Has anyone built a LNF head? or Ported one yet? Or does anyone plan on doing so in the future? Im assuming the LNF head flows similar numbers to the LSJ head, and if this is true, then the exhaust side is still pretty restrictive. It would be interesting to see what you can do with a ported LNF
Old Feb 16, 2009 | 05:57 PM
bootymac's Avatar
yeah that and a ported throttle body is what i would like to see done........ the lsj's numbers on the ported throttle body is like 6 at the wheels. Im wondering if there is anyone willing to do this as a project to see how much is gained. If it's good gains i would def consider doing this.
Old Feb 16, 2009 | 06:01 PM
Area47's Avatar
Rent me! per hour
hate to say it, but until the fuel problem is taken care of. there is no point in doing head work. the wall at 400hp is still going to be there
bootymac's Avatar
what about a ported throttle body?
Old Feb 16, 2009 | 06:21 PM
Area47's Avatar
Rent me! per hour
pointless for it. the tb matching the charge piping
Old Feb 16, 2009 | 09:39 PM
Baldturbofreak's Avatar
Do NOT change the throttlebody/intake bore in ANY way.
Backup fueling calc's (VE lbs/min in HPT) are based off the pressure drop measured across the T-map and MAP sensors.
It's done in a manner similar to a flow bench, IE pressure drop across a KNOWN orifice size.
Chop it up and you'll be replacing it.
Old Feb 17, 2009 | 01:05 AM
i was more curious with what kind of numbers you can push out of the stock turbo after head porting.
BTW, can you explain the wall at 400whp to me? i know its there, but im not sure why...unless its just that no one has made larger fuel injectors that will work for the DI LNF?
Old Feb 17, 2009 | 01:07 AM
08BlackSS/TC's Avatar
That would be correct
Old Feb 17, 2009 | 01:14 AM
ls1fbody's Avatar
Haz l33t wheelz.
the turbo's available will be able to outflow the amount of fuel available haha. and yes, there just aren't injectors big enough to supply fuel after 400hp.
ineedacobaltss
Nov 7, 2015 02:25 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
dennis69
Oct 20, 2015 04:49 PM
Sep 28, 2015 12:51 PM
