help with a cel
Old Feb 9, 2010 | 02:19 PM
StyleandSpeed's Avatar
help with a cel
I've researched till some extent but couldnt find a rite answer due to limited time available on hands, anyways last night I had a CEL go off and went to my local advance auto parts so they can check it out with a code reader. Anyways before I got to see wut the code was he deleted it and said it was no big deal,had something to do with a turbo sensors (wut the code reader exactly said) guessing that would be my intake? I have a dejon sri btw.
Old Feb 9, 2010 | 02:42 PM
Terminator2's Avatar
I Need to know what number the code was to help you.
Old Feb 9, 2010 | 02:48 PM
Yea I know srry I provided vague detail, im gonna go again today tho to get the exact code, prolly something to do also with my vacuum lines, my friend dicked around with those when he installed my BOV, could be because im running my blow off valve and my bypass at the same time also.
Old Feb 9, 2010 | 02:58 PM
Probably a BPV code. Maybe the vacuum lines are hooked up wrong.
Old Feb 14, 2010 | 04:28 PM
Alrite so the cel code was p2261
Googled and searched and found this thread and it explained everything to me,
http://www.hptuners.com/forum/showthread.php?p=204342
"The ECM by comparing the measured MAF to the modeled MAF has detected a series of pulsations in the induction system that exceed a calibrated threshold.
Plain english: valve not opening when the solenoid commands hehe."
My question is,is it ok to drive around with the BOV and the bypass together? im getting a bypass plate soon to block it off just never got around to buying one.
Old Feb 14, 2010 | 09:40 PM
08SSTCRD's Avatar
At least part of your problem is the fact that you are running a BOV. These cars are equipped with mass air flow sensors. The only proper application for a BOV is on a car that is either speed density from the factory or tuned to be speed density.
What you are basically doing it venting air to the atmosphere that has already been measured by the PCM. So it thinks all that air is going to reach the engine, but its not. This can throw off the MAF, MAP, and O2 sensors.
Go back to the stock diverter setup and the problem should be eliminated.
Old Feb 16, 2010 | 04:32 PM
hmm so you're saying even with a delete plate and a retune it can do long term damage? I got the BOV because I plan on upgrading the compressor wheel.
turbochargedss2012
Sep 20, 2023 12:17 PM
Cobalt08LS
Jun 19, 2016 07:29 PM
Dustin24
47
Feb 12, 2016 04:10 PM
DocSvensk
Sep 27, 2015 02:24 PM
jcarroll53
Sep 24, 2015 07:43 PM
