help with cel!
Old Jun 1, 2012 | 01:03 PM
bucks121's Avatar
help with cel!
just flashed my trifecta base tune and after a few runs i got P0036 code
does anyone know what may of caused it? i cleared it and it still didnt come back after about 15 mins of driving
Old Jun 1, 2012 | 01:54 PM
slapbetcommissioner's Avatar
Mods?
Did you Mean p0236?
Old Jun 1, 2012 | 01:56 PM
Speed_Thrills's Avatar
P0036 is O2 Sensors heater. Tune may have caused bad A/F ratios..
http://service.gm.com/gmspo/mode6/pd...F%20Engine.pdf
Old Jun 1, 2012 | 01:58 PM
willie_panic's Avatar
Trouble Code: P0036 (2.0L L4 VIN X Std)
HO2S Heater Control Circuit Sensor 2 Print this code data
Number of Trips to Set Code: 1
■CCM Details
■MIL Details
Trouble Code Conditions:
The ECM detects an open in the heater circuits of the HO2S when the heater is commanded OFF. The condition exists for greater than 4 seconds or a cumulative of 30 seconds.
Possible Causes:
■HO2S ignition circuit for a short to ground or an open/high resistance
■HO2S low control circuit driver is shorted to ground
■HO2S is damaged or it has failed
■ECM has failed
Old Jun 1, 2012 | 02:56 PM
SSlobalt's Avatar
Did you recently install a downpipe?
Old Jun 1, 2012 | 03:00 PM
bucks121's Avatar
my mods and a catless dp and a sri and tunned with trifecta. i installed the sri and downpipe awhile ago and drove with the cels on and when i tuned they went away but shortly after i tuned i got a cel for P0036
there was a mistake and i got my car tuned for gms1 sensors which i dont have could this have caused the problem? and how do i fix it
Old Jun 1, 2012 | 03:13 PM
silverbullet08's Avatar
If you recieved a tune for stg 1 sensors then you most likely will get a CEL for that soon as well. Your rear o2 isnt required for your cr to run correctly. Send Vince a email asking for the code to be deleted and the correct map sensor settings.
Old Jun 1, 2012 | 08:02 PM
bucks121's Avatar
so i cleared the cel and then flashed to stock and it was fine for a while except my car was still boosting at like 140-160 kpa and then later when i restarted it now it has really loud turbo flutter and at first start up high boost was making the car buck and now i have the P0036 code and along with the code P2227 any idea whats wrong?
Old Jun 2, 2012 | 12:05 AM
SSlobalt's Avatar
P2227 only comes from the GMS1 flash not being completed correctly.
turbochargedss2012
Sep 20, 2023 12:17 PM
Cobalt08LS
Jun 19, 2016 07:29 PM
Dustin24
47
Feb 12, 2016 04:10 PM
DocSvensk
Sep 27, 2015 02:24 PM
jcarroll53
Sep 24, 2015 07:43 PM
