HELP installing HP tuners problem
im trying to install the software and i cant open the VCM editor nor the scanner... this is the error that comes up:
"this application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem."
ive try to restart the computer, ive "repair" the wizard... i just dont know what to do! HELP!
Windows XP is pretty HP tuner friendly Vista and 7 can be a little more difficult sometimes. Unistall then reinstall the drivers. Then check to make sure both drivers are installed. Ifonly one driver is installed it will not work.
Cardo should be able to look in Control Panel> System> Device Manager with the interface connected and see if any devices show a driver error. They would show up with a Yellow Splat if I remember right.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
