help me... with a wastegate pic
hello im a 2.2 turbo as some know. does anyone have a pic of the wastegate on the stock turbo mounted and in the car or out? i either hit 14 psi or none... need some help here its annoying i want around 8-10psi. thanks!
i have one.. my bracket is f'ed up so only 1 bolt holds the actuator on..right now its as close to ctock as i can get it but 0 psi..if i change it i spike 14 psi
thatd be great! i think i got it. i adjusted it so the rod was almost all the way over.. fullboost is 11-12.. im gonna let cool off and adjust it all rthe way over and may dial in with boost controller
