Help with trouble codes!
Old Mar 15, 2013 | 03:47 PM
20BLACKBIRD02's Avatar
Okay guys, I got in a wreck a few months ago from an dumb ace running a stop sign, got my car fixed, now its running around 10 pounds of boost but will slowly go up to about 12, and I have a trifecta tune and all the piping is connected correctly, but I have about 6 trouble codes...
P013E
P2096
P0036
P2270
P0137
P2195
I know its not much to go on, but if someone could tell me what these are and could tell me how to fix it! thanks guys!
Old Mar 15, 2013 | 07:47 PM
4g63killer's Avatar
Boost leak
Old Mar 16, 2013 | 02:44 AM
so that would cause all those codes??
Old Mar 16, 2013 | 01:55 PM
SSlobalt's Avatar
Well, you've just thrown every post-cat O2 code imaginable, so you probably need to start there. Make sure your post-cat 02 wiring is good from the sensor to the plug near the driver's side wheel, then make sure your pipe isn't crushed, then make sure the cat isn't clogged. Report back. All the DP mounting bolts are probably just loose.
Old Mar 16, 2013 | 03:34 PM
Well I have a Cat less down pipe with the o2 bung, so could thy also be why it would throw those?
Old Mar 16, 2013 | 05:20 PM
Aleksey's Avatar
A lot of those rear o2 codes could just be disabled via EzFlash
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
