Help!!! Wierd little problem
Old May 1, 2009 | 01:02 AM
SaleenFreak's Avatar
Ok, well i have a question, just want you opinion on what the problem might be before going to warranty. when i am wot in second gear around 4000 to 5000 rpm the cars cel light flashes and blurp sound comes out of the exhaust. it only does this around 180 coolant temp.
Old May 1, 2009 | 01:55 AM
Zander916's Avatar
Misfire would be my guess.
Old May 1, 2009 | 02:09 AM
agent007kimball's Avatar
I would say misfire as well.
But on a side note, whats with people beating on these cars when they are not yet up to proper temp? Wait until around 192 degrees holds steady for a minute before you start to wail on the thing. You need to allow your oil to get up to temperature as well....not just coolant.
Your engine is not going to last long if you abuse it before proper temp is reached.
Old May 1, 2009 | 08:19 AM
BartSS's Avatar
Its a misfire for sure. I had It happen once. It turned out I had a bad ignition coil which the dealer took care of. So yeah. When it flashes call onstar and they will give you the code and then go to your dealer
Old May 1, 2009 | 09:04 AM
Terminator2's Avatar
Yep. It sounds like a misfire. 180* is warmed up Enough to where ther should be no issue there. Maybe a coil pack going bad that would be my guess.
Old May 1, 2009 | 11:01 AM
Thanks!!!!
Old May 1, 2009 | 11:35 AM
80vetteL82's Avatar
+1...I wont even give it more than a 1/4 throttle until Im up to operating temp. I watch it like a hawk until its at 195+, and until that point I only give it enough throttle to actually move haha.
Old May 1, 2009 | 11:50 AM
turbaltss's Avatar
I've thrown 1 cel and it was when I did a nls from 2to3 and my car wasn't fully warm yet about 85c (ussually runs at 91-93c) I'm canadian eh!
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
