High Boost High RPM Misfires
Old Jul 18, 2017 | 09:14 AM
umrdyldo's Avatar
Originally Posted by Darkfuzion
I thought I should give this an update since a recent development.
My car has always had slight issues with misfires and I seemed to have always "fixed" them by changing different things, tunes, plugs, seals etc... Just recently my car started misfiring excessively when it hit 10lbs of boost. I did a compression check today and found 120lbs on cyl 1, 90 on 2 and 150 on 3 and 4.
Clearly there is an issue with the internals and ideally I should be able to just replace the rings unless anything else is damaged but I wont be able to tell until I take the motor apart.
Make sure you do a compression test if you are having issues resolving misfire issues, I should have done this long ago.
Time for an engine swap. It's the new cool thing to do.
Old Jul 18, 2017 | 12:36 PM
CudaJoe's Avatar
Originally Posted by Soofisahab
Got a hold of Vince after a min, he looked at datalogs and all appeared good: hpfp, maf and map readings, etc.
I read about problem solved with replacement of spark plug boots...whatcha know playas
Rubber in my coil boots had deteriorated and was caught in the springs, as well as dielectric grease baked onto springs from me putting a dab almost everytime I changed plugs. I sprayed MAF cleaner in boots and let it sit, then scrapped away the mess in the springs, reapplied a sensible yet masculine coating of dielectric grease on the exterior of boots and ITS FIXED!!!!!!!!!!!!!!RAPED APE status again WOOT!!! THANK GOD!
Next step was a compression test, blown injector seals and valve gunk can cause similar.
weird seeing this guys posts still every now and then when an old post gets bumped. ******* terrorist. How normal this guy seemed until he went crazy.
Old Jul 18, 2017 | 12:56 PM
exninja's Avatar
I don't know, hindsight we prob shoulda seen it coming. "Raped Ape status"??? Red flag if I ever saw one.
Old Jul 18, 2017 | 02:32 PM
LNFwagonSS's Avatar
Huh? What did I miss?
Old Jul 18, 2017 | 03:54 PM
tomj77's Avatar
Shouldnt he have said thank allah. Terrorist bastards, too bad he had too take a lnf with him too hell.
Old Jul 18, 2017 | 03:57 PM
tomj77's Avatar
The dude he quoted was one of The guys who tried to attack a comic convention was it? In the states bout a year or so ago. Don t think they got too far , they got their ass shot. Pulled up in an lnf with assault rifles and stuff. The cops were afraid the car had a bomb so they detonated an explosive on the back of the car. By by lnf.
Old Jul 18, 2017 | 03:58 PM
tomj77's Avatar
Someone post the news link
Old Jul 18, 2017 | 05:34 PM
LNFwagonSS's Avatar
Wow...
Old Jul 18, 2017 | 07:41 PM
You're correct. Down in texas they barely made it away from their car before people on site had them.
Old Jul 19, 2017 | 11:47 PM
Darkfuzion's Avatar
Well friends, look like I broke a lash adjuster and had 2 rocker arms fall off. One of the rockers fell of the exhaust side of cyl 1 and the other fell off the exhaust side of cyl 2.
I would love to just buy new lash adjusters and put everything back together, do a compression test and see if were good to go. Or should I pull the head, and take a look at the pistons to see if they are cracked or have broken ringlands , thoughts?
Thanks
Old Jul 20, 2017 | 09:22 AM
  #36
jdbaugh1's Avatar
What causes these to break? Over-rev?
Old Jul 20, 2017 | 09:45 AM
  #37
tomj77's Avatar
His username was banned cause he was terrorist scum
Old Jul 20, 2017 | 09:48 AM
  #38
Thank you.
Old Jul 20, 2017 | 10:40 AM
  #39
Darkfuzion's Avatar
Yes, over-reving causes this issue. Hopefully its not too damaged when I take the head and pistons out today. Could have a cracked piston or broken ringland.
Old Jul 20, 2017 | 01:22 PM
  #40
tomj77's Avatar
Thank you.
I don't think it was me, someone did though
Old Jul 30, 2017 | 11:16 PM
  #41
Darkfuzion's Avatar
Ok guys, I need some some. For some reason this car still misfires once I get into boost. As you can see in my post this has been a very long and ongoing issue. Today I just finished installing all new lash adjusters, pistons/rings because I cracked the ring lands on cyl 1 and 2. Once everything was put back together the car started up just fine, it also runs great with no cel's unless you go WOT into boost, then it massively misfires and the cel flashes.
The car has these issues on a ZZP tune to so I went back to my Trifecta tune and it still had issues so now its on a stock tune and had the same results. Of course since I had the engine apart I already check everything that causes this. Seals on the injectors, plugs, sensors, valves (cleaned). I data logged the misfires and sent them to Trifecta but other than that I have no clue what to look for next.
Old Jul 31, 2017 | 11:18 AM
  #42
exninja's Avatar
I'd redo the compression test and see if you still have low compression on 1 and 2. I wouldn't think broken rockers would cause low compression numbers.
Old Jul 31, 2017 | 12:46 PM
  #43
Darkfuzion's Avatar
We tested all of them when it was put back together 150PSI across the board. The broken rockers weren't the cause of low compression. The cracked ring lands on cyl 1 and 2 were, that was fixed with new pistons/rings.
Old Jul 31, 2017 | 08:44 PM
  #44
63 Nova SS's Avatar
Do you have hp tuners? You could log the car until it starts to misfire and see if one of the guys could take a look at it. I wouldn't go into boost unless you had to. It's not tuned for e85 and your running gas is it? Leaning out or too much timing can kill the motor.
Old Aug 2, 2017 | 02:37 AM
  #45
Darkfuzion's Avatar
It ended up being 1 bad coil pack on cyl 3. I only have had these coil packs for about a year but apparently 1 didnt last that long. Thankfully it's all good to go now but it was extremely confusing to do all that work to replace the pistons only to have a similar but different misfire issue.
turbochargedss2012
Sep 20, 2023 12:17 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
no_ss
Oct 18, 2015 11:58 PM
717ssbalt
Oct 2, 2015 04:01 PM
Slick_Nick
Sep 28, 2015 09:15 PM
