High Coolant Temps?
Old May 23, 2011 | 10:19 PM
RYRO14's Avatar
High Coolant Temps?
After doing 3rd gear and up pulls, my coolant temps get pretty high like 215-225 degrees. They used to get to like 205 degrees top. I am combo tuned at 22-23 PSI, K&N intake, CP, DP and Treadstone IC. I rencently had the engine rebuit because I blew by the dealer if that has something to do with it.
Old May 24, 2011 | 12:42 AM
RyanJM's Avatar
Usually higher temps are caused by a bad radiator or stat most of.the time.
Old May 24, 2011 | 01:03 AM
rivaladore's Avatar
Thermostats fail open so therefore his coolant wouldn't be getting that hot
Old May 24, 2011 | 01:43 AM
Tomtwtwtw's Avatar
Turbo is water and oil-cooled...coolant temp will shoot up very quickly on 3rd and 4th gear pulls, even faster with more boost. That said, 225 is nothing. There is nothing wrong with your car.
Old May 24, 2011 | 02:47 AM
RyanJM's Avatar
I had a thermo get stuck closed on my old 5.0. They usually get stuck open but not always. Hell in FL I used to.run my celica and grand am with no stat. Just no heat on the Fe cold.days there were
Old May 24, 2011 | 02:58 AM
Rocky87's Avatar
on hot days just at idle my car can reach 200 i think its normal
Old May 24, 2011 | 11:49 AM
gone_in_10_sec's Avatar
Yep, when doing a hard 2nd or 3rd WOT pulls - temp spikes high.. its normal.
Wondering are your fans kicking in? if not, have your fan set to turn on at 188*, my temp stay under 193* all day in 85-95* heat, but once in a while - on really hot days 100*+ it goes up to 203* but stays there when the fan are on..
Once a year, every spring I do a complete rad flush and hose inspection, some say no need to, but better to be safe than sorry.. i've seen some radiators with funky stuff coming out of them, when they where being flushed..
brandon04
Oct 21, 2015 07:04 AM
no_ss
Oct 18, 2015 11:58 PM
Slick_Nick
Sep 28, 2015 09:15 PM
jmelton327
Sep 26, 2015 10:04 PM
riceburner
Sep 26, 2015 12:57 AM
