High RPM misfire when mapping.
Old Feb 18, 2018 | 10:43 AM
briangorman's Avatar
Hi everyone I am from the UK and looking for some advice and routes to go.
i have Opel Astra J Vxr which has LHU engine which is basically the same as the LNF which was running 415hp / 420 lb-ft at 1.8 bar but dropped it to 1.6 bar till I sort the problem and all on pump gas. I bought it from new in 2012 and currently on 38000 miles.
There’s only 2 or 3 running this power in the UK so not much info to go on.
my spec,
tubular Manifold with EFR 7163 turbo
Turbo back with no cats,
Airtec intercooler,
Pro alloy Radiator,
EP induction kit,
Fully Forged Engine,
Stage 2+ cams,
Stage 4+ clutch,
Uprated Valves and valve springs,
Balancing Shaft Delete,
HPFP
When the car is being live mapped on the dyno there’s a slight misfire round about 5500/6000 rpms so makes a dip in the graph at the end.
My tuner is saying either the coils or the sparks plugs or both are not up to the job so been looking at ZZPs coil packs and ACdelco plugs, would use recommended these? Or what plugs and coils would use recommend?
the coils and plugs have been changed twice already and still the same result. On standard coils and NGKs plugs.
Pictures to show what my car looks like and what I have done to it. Also what the plugs look like after about 6000miles.
Attached Thumbnails b4a26ec8-8a47-4070-a6a2-16d8e2994ab4.png   67ab9764-3cdf-48d3-8ce7-49fb7fd15b93.jpeg   2feec75b-fe5d-4e3b-818a-85b5ad2ec8e6.jpeg   22d3782c-279d-493d-8874-b86946788aa1.jpeg   df359c74-13f5-41f1-8969-9499f2df8a94.jpeg
Old Feb 18, 2018 | 10:48 AM
What gap are you running the plugs? Also that looks like the tune is stupid rich, for a DI engine 0.85 lambda is rich enough to be safe.
The stock coils have enough voltage.
Old Feb 18, 2018 | 10:59 AM
The gap is stock so 0.8mm which is about .031”.
So if the coils are strong enough and the gap is correct it would be the tune is too rich then?
Old Feb 18, 2018 | 11:29 AM
I'd try pulling the gap down to 0.028" and see if the blowout disappears.
Going to a "leaner" lambda of 0.85 might help but I'm not sure what your car is running at now. I run my LNF at 0.88 on pump.
Old Feb 18, 2018 | 02:36 PM
Brilliant thanks for that, Will message my guy and see what it’s running then hopefully get it in during the week to see if that helps. Will report back once it’s done.
Old Feb 19, 2018 | 06:10 AM
63 Nova SS's Avatar
What Ecaulk said. You can try .028 on the gap just to see if it helps, and use the acdelco plugs.
Old Feb 26, 2018 | 09:49 AM
Thanks for your help. My car was running 0.82 lambda with stock gap for plugs but got the car mapped today with it running 0.85 lambda and a gap of .028” for the plugs and now has sorted the issue.
it made 413bhp, the graph above shows it hits a wall and doesn’t keep climbing. Stays at 413bhp for most of it.
does the power sound right for what I have done to the car?
if not would it help by raising the fuel pressure as that’s still at stock?
or possibly the injector could be slightly out of sink?
low-mid range is all good but when it gets to the high end it just doesn’t want to give anymore.
Old Feb 26, 2018 | 12:37 PM
umrdyldo's Avatar
If you have the stage 2 cams with upgrade fuel lobe you may need to up the fuel pressure a bit
Old Feb 26, 2018 | 02:06 PM
yes i do have stage 2 cams with bigger fuel lobe. What’s stock fuel pressure? and what’s safe to put it upto?
Old Feb 26, 2018 | 02:12 PM
umrdyldo's Avatar
GM Stage 1 fuel pressure.
Here is the GM Stage 1 fuel pressure table. You need to be logging commanded pressure vs. actual to make sure you aren't running out of fuel if you do raise the pressure.
As for what to bump it up to, I'd try bumping it up just a little and see if it can meet that pressure. I would start with 16 max and see if it changes.
Old Feb 26, 2018 | 03:30 PM
umrdyldo's Avatar
Also which HPFP are you running?
If you are truly running out of fuel then switching to the LT1 direct injection pump might be your next step.
I doubt you are running out of fuel though.
Old Feb 26, 2018 | 03:45 PM
Thanks a lot for all that info.
actually I have a ASNU fuel pump which is in the tank and that does the low pressure side. I still have stock pump for High pressure side. I take it the next step is to change out the High pressure side?
Old Feb 26, 2018 | 04:11 PM
umrdyldo's Avatar
Yes
If you do find you are actually running out of fuel, contact mongorat427 on here.
He installed the Corvette LT1 and LT4 high pressure pump. I think you need adapters but I'm not 100% sure. The LT4 runs much higher pressure and flow than the LT1 or LHU HPFP.
https://www.cobaltss.net/forums/2-0l...l-pump-324991/
I am not sure if he has test fit one to other platforms but I'm guessing it works just fine.
Old Feb 26, 2018 | 04:26 PM
Yes
thanks a lot for that. How much are the HPFP? As ZZP have a direct fit one for $700. What one would you recommend?
Old Feb 26, 2018 | 05:13 PM
umrdyldo's Avatar
mongorat427 is the guy to talk to.
I honestly have no idea on price or where to get it.
Old Feb 26, 2018 | 06:31 PM
thanks for all that again. Messaged him and bought the kit.
should be with me by next week latest.
is it as simple as install the HPFP then map it? Or will the fuel pressure need changing?
Old Apr 23, 2018 | 02:41 PM
So went to get the car finally mapped today and it went all bad. Done 1 dyno run to check if it was all ok but was down a little power then done 2-3 other runs and by the end of it was down 80bhp. So turned the car off then turned it back on and was a really loud knocking noise so engine needs to be fully stripped down now to check crank, rods, pistons etc to see what the damage is.
Is there a uprated crankshaft for it? And also is the oil pump good enough to run this power or does it need uprated?
Old Apr 28, 2018 | 12:57 AM
tomj77's Avatar
ur gap is to big. I had bad blowout at stock gap on my 257. lower to .028 like stated. and lean out ur lambda to .87. even .85 is rich .87 is just fine. even .88 is good.
Old Apr 28, 2018 | 05:04 AM
My new plugs were gapped at .028 and lambda is .85
do you know if there is an better oil pump or is standard fine?
Old Apr 28, 2018 | 08:36 AM
Engine is warped etc so fucked, looking at getting the shell of an engine, rods and piston.
think it was down to an oil issue so getting to warm. Is there any upgraded oil pumps? Looking at fitting a oil cooler aswell.
is there any better design than the plastic guides for the timing chain?
here is the damage.
Old May 7, 2018 | 08:02 PM
tomj77's Avatar
What the check happened. I have similar issue at same rpm. Popcorn backfire though. Dont Think nothing is broke though. How did ur rod break
Old May 8, 2018 | 02:49 AM
the oil lines run very close to the turbo so reckon the oil got cooked before it went into the engine, So all the lines are being relocated along with new engine etc.
Old May 8, 2018 | 06:14 AM
63 Nova SS's Avatar
Aftermarket rods broke and the crank got trashed, can't say I've seen that happen a whole lot. How high were you revving it? I've done several dyno pulls before and never had issues. Can't believe you trashed the engine just doing that. What kind of power were you making? Was the clearance in the bearings too tight?
Old May 8, 2018 | 07:24 AM
yes all trashed and engine is warped aswell. Revs were set at 7k. I was only making 420bhp, should of been a lot more but just wouldn’t make the power. That could of been a possibility but not sure. There’s some serious heat damage so reckon was down to that and cooked the oil.
Old May 8, 2018 | 08:58 AM
tomj77's Avatar
ya I did that before new engine even went in
RHKJSB06
Apr 3, 2012 01:10 PM
godsfshrmn
Feb 26, 2012 09:05 PM
Hopeless Regret
Oct 28, 2007 12:13 PM
