how do u put the motor at TDC
Few options. First you can pull a coil and plug, stick a long screwdriver down the spark plug hole, rotate the crank until it crests.
Or with the serp belt off, there is a dash missing in the rear of the pulley, match that to the timing mark on the cover, located at 11 o'clock or so, use a mirror to be sure it's lined up
Can't u tell cause the rod would be moving up or down lol
I'll get me a rod, and it's right when the piston is at the very top yes?
I would say the easiest way is to remove the valve cover and watch the valves. Intake side are towards the front of the car and Exhaust are towards the firewall, at least on a LSJ engine. You can see the intake valves go down and then the exhaust valves that will tell you which stage on the of the stroke it is on.
The other way would be to watch for the timing arrows on the cam phasers. When they're actually visible, you're at TDC compression stroke cylinder 1.
I know TDC is technically at the top of any of the strokes, but TDC for timing has always been on the compression stroke. All valves closed. That hasn't changed, I hope.
i found myself a 2.2l motor for a few hundred buck
totally gonna teach myself how to take a motor apart and put it back together till i can do it with my eyes closed. lol
ThoR294
Oct 4, 2015 08:44 PM
