How does the K04 wastegate/boost controller work?
Old Aug 26, 2010 | 12:09 PM
ebristol's Avatar
There seems to be a lot going on here.
1. Internal Wastegate
2. Boost Supply Line
3. Boost Supply Line
4. By Pass Valve
Old Aug 26, 2010 | 01:01 PM
Wickedlsj's Avatar
I'll have to look at my turbo again but one is for the for the bypass (probably 3) and the other runs to the solenoid on the intake manifold, which goes to the cold side charge pipe. If you're installing an aftermarket turbo all you need is:
1. Wastegate at diaphragm
2. To cold side charge pipe
3. Open
Old Aug 26, 2010 | 01:04 PM
CobaltVenomSS's Avatar
can i buy a vowel? "A"!!!
Old Aug 26, 2010 | 02:12 PM
ebristol's Avatar
Anyone?
I know there are some smart LNF guys around here.
Old Aug 26, 2010 | 02:23 PM
jimbos'ss's Avatar
Originally Posted by ebristol
Anyone?
1, pressure inlet for the wastegate diaphram
2,3 are the boost feeds for the electronic boost controller solenoid
4 vacuum line for the BPV
you planning on installing it on an LSJ? if so I've already done it and can help out a bit.
Old Aug 26, 2010 | 02:32 PM
northvibe's Avatar
Ya isnt 4 the BPV?
Old Aug 26, 2010 | 02:33 PM
ebristol's Avatar
BPV?
Well I would never go straight turbo but a local guy was talking about doing it to his LSJ. So I thought I would do some digging around.
Did you use the boost controller on the K04 or did you use your own? I am going to search for your threads.
Old Aug 26, 2010 | 02:36 PM
jimbos'ss's Avatar
BPV?
Bypass Valve
right now i'm using a manual boost controller, plans are to hook up this boost controller to the stock SC boost bypass harness if i can figure everything out. looks promising so far, just need an EV1 connector.
Old Aug 26, 2010 | 02:42 PM
ebristol's Avatar
Bypass Valve
Gotcha. So it connects some where on the IM?
So the connection on the K04 boost controller uses a EV1 connection? So then you just need to find out how the PCM communicates to the boost controller. My guess is that it would be based of some sort of linear voltage signal.
You don't have a build thread started for this turbo setup do you? Cause I couldn't find anything.
Old Aug 26, 2010 | 02:47 PM
jimbos'ss's Avatar
yes hooks up just like a BOV
i do have one, just not on here(mavens place-"did some work today"). and yes i believe it is linear voltage much like the LSJ bypass valve solenoid. there's even some nifty controls like steady state, prop speed and gain available in HPT. hopefully i can make it work just like a normal electronic boost controller.
Old Aug 26, 2010 | 02:51 PM
SSlobalt's Avatar
So, that's our K04? Damn, that thing is LITTLE.
Old Aug 26, 2010 | 02:54 PM
northvibe's Avatar
I can take pics when I'm off work in a few hours
Old Aug 26, 2010 | 02:56 PM
jimbos'ss's Avatar
packs a decent punch for being as small as it is, 36lb/min max is nothing to sneeze at, works even better on my slightly higher compression motor.
Old Aug 26, 2010 | 02:59 PM
SSlobalt's Avatar
But it's so cute.
Old Aug 26, 2010 | 03:01 PM
ebristol's Avatar
Makes sense.
But you wont be able to control the K04 boost controller through the LSJ PCM unless you can adapt it to the SC by-pass valve signal right?
Did you have to replace the coolant cross over pipe on the LSJ or where you able to clock it to allow enough clearance for the turbo?
Old Aug 26, 2010 | 03:04 PM
jimbos'ss's Avatar
Makes sense.
thats the plan is to use the SC bypass signal when i swap pigtail connectors to the EV1
yes you must get the LNF coolant cross over tube, no way around it, its not even the turbo that won't clear it, its the manifold itself that hits. the LNF manifold is significantly bigger than the saab one.
Old Aug 26, 2010 | 04:11 PM
ebristol's Avatar
I see.
SSLOW06
Oct 1, 2015 07:21 PM
OPCrer
Sep 27, 2015 08:11 PM
jmelton327
Sep 26, 2015 10:04 PM
Coballin13
Sep 25, 2015 08:43 AM
