How fast do u go through meth?
Old May 27, 2012 | 06:18 PM
06cobalt racer's Avatar
most have them installed right before the nozzle. but as it is installed it shouldnt matter too much
Originally Posted by tylerjclance
how's your meth kit running? Are you tuned for it yet?
nope not tuned for it yet. my tuner went back to the states. i need to find someone with hp tuners so i can finally get tuned.
Last edited by 06cobalt racer; May 27, 2012 at 06:18 PM. Reason: Automerged Doublepost
Old May 27, 2012 | 07:47 PM
Gunney_07's Avatar
Just before the nozzle ... you want to limit the residual meth in the line that the motor could suck up in vacuum.
Old May 27, 2012 | 09:55 PM
slvrred-'s Avatar
Installed check valve right before the tb and everything is A-Ok! Thanks for all helps guys!
Old May 27, 2012 | 09:59 PM
no problem
Old May 27, 2012 | 10:33 PM
slvrred-'s Avatar
Well how about the new problem I've caused myself. When i reinstalled the line to the pump, the bulkhead fitting moved just a bit. Now I have a leak. Any ideas on how to seal it back up? Btw I have the stainless braided line upgrade and the directions say not to use teflon tape, just like it said "DO NOT OVERTIGHTEN." god I could kick myself right now.......
Old May 28, 2012 | 09:21 AM
Gunney_07's Avatar
can you show a picture of the piece you speak of?
Old May 28, 2012 | 09:31 AM
MP Cobalt's Avatar
Your honestly lucky you didn't pull to much and blow the motor. Since you weren't running a check valve
Old May 28, 2012 | 09:59 AM
slvrred-'s Avatar
I can try and get a pic later, at work at the moment. I believe it's a -06 or -04 an fitting that threads into the outlet port of the meth pump....I'll try to get a picture up in a few.
Old May 28, 2012 | 11:50 AM
slvrred-'s Avatar
Here are two quick pics. The part that is leaking I pointed to with the pen.
Old May 28, 2012 | 03:48 PM
Gunney_07's Avatar
Is it leaking on the pump side or the hose side?
Old May 28, 2012 | 04:09 PM
  #36
slvrred-'s Avatar
Pump side. I tired some expoxy on it to see if it will seal the threads. I made sure to not put any too close to where the meth travels through. Devils own says not use Teflon tape so I didn't, lol.
Old May 28, 2012 | 04:30 PM
  #37
Gunney_07's Avatar
They really don't want anything on the threads for the exact reason you mentioned, you don't want that plugging up your lines that starts a whole new head ache. Hopefully this works and you have no issues. But If it still leaks obviously replace that adapter and hope it didn't screw up the threads on the pump. How does this seal? Does it use an o-ring or does it depend on the threads? Mine is a plastic line press connect fitting.
Old May 28, 2012 | 05:00 PM
  #38
slvrred-'s Avatar
It seals with the threads and I put it far enough away from where the meth runs thru it. If you look at the second pic I posted I just put some on the last three or 4 threads towards where the black nut is. It should be far enough away that it shouldnt cause any problems. I'm keeping my fingers crossed.
Old May 28, 2012 | 05:15 PM
  #39
Gunney_07's Avatar
Sounds like it should work good luck!
Old May 28, 2012 | 07:06 PM
  #40
slvrred-'s Avatar
Thanks. Should know by tomorrow. Full cure is 24 hrs so there's not going to be any spraying till then.
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
