how the lnf crank breather system
Old May 7, 2016 | 03:29 PM
tomj77's Avatar
well for any of u who want to know how the lnf crank case vent system works, here it is. started tearing my engine apart to test some things, like if there is a block in the breather system. this is how it works.
ok if u take off rocker cover u have 4 ports in the head for the vent system. 1 on the back, 3 in the front. the one on the back is connected to fresh air intake from the air intake. the hose with check valve, this port goes all the way to the crank case. that's how it gets fresh air. then u go to the 3 in the front. the 2 on either side and one in the middle. the sides ones come up from the crank case, so it seems, and directly into the valve cover. the one in the middle goes directly to the pcv valve in the intake manifold and nowhere else. so how it works. when ur in boost fresh air comes in to the back one to the crank case, and back up to the rocker cover where it exits the port in the rocker cover that goes to the turbo, and the air goes back into the intake system and reburned. the pcv valve in the intake manifold is held closed by boost so nothing goes that way. the sucktion of the turbo provides the vacuum for the system to work under boost. when engine is in vacuum and not boosting there isn't enough suction from turbo to make it vent, so the pcv takes over, it is open in vacuum so all the venting of the crank case goes through that middle port on the head that leads to the pcv valve and back into intake manifold to be burned in combustion.
so hope that explains it, that's how I can see it works.
Old May 7, 2016 | 03:30 PM
tomj77's Avatar
sorry for spelling mistakes I know are in there, to lazy to look
Old May 7, 2016 | 04:47 PM
Sl0wbaltSS's Avatar
Were you high when you made this? Cause this is GENIUS!!!!!. Jk.
The PCV hose connected to the intake tube is just for fresh air to the crankcase. The one on the back on the valve cover goes to the turbo and it sucks in the Positive pressure then sends it into your intercooler and engine.
Old May 7, 2016 | 05:21 PM
tomj77's Avatar
ya that's what I said. but there is more to it than that.
Old May 7, 2016 | 05:42 PM
tomj77's Avatar
but like I said, I think, I could be wrong on some of this, this is just what I'm observing how its all routed and because of how its routed how it works
Old May 14, 2016 | 10:12 PM
Bluelightning's Avatar
Got Bewst?
Look how many ports are on the valve cover. May need to rethink your route
Old May 15, 2016 | 01:01 AM
tomj77's Avatar
Their are 2 port on valve cover that have hoses going to intake and turbo. Their are 4 ports, or passages I guess under the cover in the head, all 4 of those are part of the system. One goes down to crank case from the port on valve cover, 2 come up from crank case into valve cover which vent to turbo, one goes to intake manifold. Did I not explain this using the correct words or are u guys just not following ?
Old May 15, 2016 | 01:03 AM
tomj77's Avatar
Maybe I should take a pic and label so u guys understand what I'm saying here lol
Old Oct 24, 2018 | 08:30 PM
Balento18's Avatar
Thank you for this info! I am working on proper oil catch can system for my LNF. Any suggestions on inlet size/install route for the oil catch can?
Old Oct 26, 2018 | 08:22 AM
tomj77's Avatar
Well this is old. I'm also working on one. Tested it this morning...needs some work. Will chime in later
Econobox
Aug 26, 2019 01:11 PM
Dylan_09ss
Jun 11, 2019 08:11 AM
Keith-SS
Jun 6, 2019 05:36 PM
SINISTER
Jul 9, 2014 02:34 PM
Micone
North Pacific
Sep 22, 2007 09:41 PM
