how much hp can the stock clutch take
Old Apr 21, 2010 | 05:33 PM
boWcarroll23's Avatar
i meen i havent heard much talk about it at all so i was wondering and do u need clutch stuff with gms1 and what if you got the trifecta tune would u need then if u said the tune for all the time what if you just set the car gms1 daily driving and trefecta on race mode would you need one then?
Old Apr 21, 2010 | 05:49 PM
RYRO14's Avatar
Not with GMS1, stock clutch will be fine.
I have the 23 PSI Trifecta tune and almost full bolt-ons and it will slip in the cold weather(below about 65 degrees)
Old Apr 21, 2010 | 06:21 PM
MaxVQ35DE's Avatar
Trifecta 20psi got mine to slip in gears 3 4 and 5. Exedy hypersingle has no problems in all gears
Old Apr 21, 2010 | 06:29 PM
cubaniche's Avatar
Ive got 15700k on my balt. Believe it or not, it used to slip way more when new than it does now. Well, it does when its cold, but just barely. But honestly I cant remeber when it last slipped and I drive it pretty hard. I had a fun run the other night from third and it did not slip at all. It depends on how powerful your tune is and how much tq your pushing.
Old Apr 21, 2010 | 07:03 PM
cardelino18's Avatar
my car had full bolt ons and trifecta 30psi tune and hold it just fine... it slip sometimes but not that much... i was pushing 323whp/404wtq on a dynojet...
Old Apr 21, 2010 | 07:13 PM
tom.g's Avatar
It's not the horsepower that is the limiting factor for a clutch it's the torque. And the general consensus seems to be that anything over 340WTQ you should consider a stronger clutch if you want to put all your power down to the ground especially in the higher gears.
Old Apr 21, 2010 | 07:21 PM
MaxVQ35DE's Avatar
yea interstate driving is no fun with stock clutch and a meaty tune. It WILL slip in 4th and 5th laying into boost.
Old Apr 21, 2010 | 07:36 PM
Married w/children's Avatar
Anybody know if the Spec clutches are any good? lookin' at a Stage 3 and it wasn't that bad of a deal.
Old Apr 21, 2010 | 07:40 PM
SUKXOST's Avatar
I hope its good.....I just ordered the Spec3+ with lw flywheel :P
Old Apr 21, 2010 | 07:56 PM
i put mine in (spec stage 3) but blew my motor 3 days after... i cant really tell you how good (power wise) is... i can tell u its not as stiff as people think it might be its fun to drive
Old Apr 21, 2010 | 08:04 PM
Mike_peperni's Avatar
I assume a part of it will also depend how you drive your car.
Like doing wide open throttle from low rpm all the time probably dont help. I try to not do that !
So far so good on trifecta 22psi, sometimes in cold morning it will slip, i think it is... or its a minimal tire slip, i cant say...
Old Apr 22, 2010 | 01:02 AM
leoaa777's Avatar
/thread
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
