how much power
It's not a question of how much power it can handle as much as it is a question of how long it can handle however much power. I'm sure the long block could withstand 450 hp for 25K miles, but it would definitely handle 350hp for a much longer period of time. I'm betting the transmission gives up before the long block in most cases.
You only need springs if you're going to rev above 6500RPM. If you're making big power with a bigger turbo, you'll probably want to rev out to 7K RPM, since you're pushing enough air out of a larger turbo to get you there without running out of breath. In that case, you would want springs. You do valves only when you bend or break one. You don't need cams.
^^^Don't quote me on that, just trying to go off memory. Its been a long time since I read that info.
I know the were using the stock GM crank bearings tho and IIRC honda GSR rod bearings.
LNF's are tough motors, it all lies in the tune tho...so make sure to get a GOOD TUNE!
I wished i knew more about tuning cause then i would of gotten hptuners instead of trifecta cause vince to me atleast doesnt seem like he wants to help because everytime i send a log to him it takes him like a week to get back to me and has one word answers.
he also gets like a hundred emails and logs per day
DDing it it doesn't matter how much peak power you make as your not using it. IDK if they are anything like the Srt but drive it with out beating the hell out of it daily, and a spot on tune and 500whp is not out of the question. Though sure going WOT every chance you get will wear down the engine faster.
