how much power
Old Aug 24, 2011 | 06:33 PM
CTFinestTurbo's Avatar
how much power
So how much power can the lnf engine handle safely until you need to do internal work?
Old Aug 24, 2011 | 06:56 PM
asanti's Avatar
According to the ZZP threadsomewhere in here, about 650.
Old Aug 24, 2011 | 06:57 PM
DiabeticKripple's Avatar
i believe that is their built lnf engine
Old Aug 24, 2011 | 07:15 PM
Yea that seems Like a lot for a stock engine
Old Aug 24, 2011 | 07:18 PM
SSlobalt's Avatar
It's not a question of how much power it can handle as much as it is a question of how long it can handle however much power. I'm sure the long block could withstand 450 hp for 25K miles, but it would definitely handle 350hp for a much longer period of time. I'm betting the transmission gives up before the long block in most cases.
Old Aug 24, 2011 | 07:20 PM
I kno the bottom end can handle good power but how about the head? When should I consider doin cams, valves, and springs?
Old Aug 24, 2011 | 07:35 PM
SSlobalt's Avatar
You only need springs if you're going to rev above 6500RPM. If you're making big power with a bigger turbo, you'll probably want to rev out to 7K RPM, since you're pushing enough air out of a larger turbo to get you there without running out of breath. In that case, you would want springs. You do valves only when you bend or break one. You don't need cams.
Old Aug 24, 2011 | 08:11 PM
Mike08ss/tc's Avatar
Matt M car from zzp was not built. Stock pistons, rods. Zzp springs, cams, head ported, fuel mods.
Old Aug 24, 2011 | 08:46 PM
HHRSSouth's Avatar
They bent the rods at 5XX whp, I would say the pistons and rings probably should be replaced around the +450 whp mark?
Old Aug 24, 2011 | 08:47 PM
but like the one guy said, if your at 450 whp it wont last as long and 350. so if you want 400+ i personally would build the motor for longevity
Old Aug 24, 2011 | 08:49 PM
HHRSSouth's Avatar
Also pretty sure the Ecotec racing team used a stock crank to 1k whp with modifications to the oiling passages?
^^^Don't quote me on that, just trying to go off memory. Its been a long time since I read that info.
Old Aug 25, 2011 | 03:00 AM
Fastgti69's Avatar
they said you're cool running between 400-420 whp.. anything higher is pushing it for a bent rod.
Old Aug 25, 2011 | 02:51 PM
Supercharged Guy's Avatar
Everybody is going to say something a little differnet then one another, I was told anywere from 400-440 is pretty safe
Anything higher then that is pusing it a little
Old Aug 25, 2011 | 03:40 PM
F_Imports_09tc's Avatar
452.378956 crank horsepower is the exact amount IIRC
Old Aug 25, 2011 | 03:41 PM
brainchasm's Avatar
I'll be doing springs, sleeves, and pistons at 350whp in prep for 450whp. Better safe than sorry.
Old Aug 25, 2011 | 03:45 PM
Shibito's Avatar
400whp reliably for years. 500whp for one year. Most important thing is the tune though.
Old Aug 25, 2011 | 04:00 PM
with the mods that i have and adding meth what kind of number could i see out of my car?
Old Aug 25, 2011 | 04:03 PM
vahdyx's Avatar
I personally am not going in the 400s, My goal is to be at 350-375whp and no higher. To me that's reliable.
Old Aug 25, 2011 | 04:15 PM
newt's Avatar
99% possitive GM used the forged Eagle crankshaft (now discontinued) in their drag engines.
I know the were using the stock GM crank bearings tho and IIRC honda GSR rod bearings.
LNF's are tough motors, it all lies in the tune tho...so make sure to get a GOOD TUNE!
Old Aug 25, 2011 | 06:14 PM
i def want to do a turbo upgrade and get meth but i wanna make sure that my car can handle it since its my daily driver.
Old Aug 25, 2011 | 06:16 PM
I wished i knew more about tuning cause then i would of gotten hptuners instead of trifecta cause vince to me atleast doesnt seem like he wants to help because everytime i send a log to him it takes him like a week to get back to me and has one word answers.
Old Aug 25, 2011 | 07:29 PM
he also gets like a hundred emails and logs per day
Old Aug 25, 2011 | 07:39 PM
Yea that is true I've just heard other people getting better service than wut I've seen.
Old Aug 25, 2011 | 07:53 PM
Perfect.disguise's Avatar
25K, thats alot of WOT driving
DDing it it doesn't matter how much peak power you make as your not using it. IDK if they are anything like the Srt but drive it with out beating the hell out of it daily, and a spot on tune and 500whp is not out of the question. Though sure going WOT every chance you get will wear down the engine faster.
Old Aug 26, 2011 | 01:28 PM
I want to reach the 375-400whp mark and ill be happy i jus dont want to break my car since its my daily driver.
